xilgaro
splitting a string in two parts
Hi, all:
I have a string with spaces. I'd like to split the string in two parts, in the first part I want one of the word of the string, let's say the third, and in the other part I want the rest.
I mean:
String= "first two three fourth fifth"
String_1= "three"
String_2= "first two fourth fifth"
In principle I don't know the number of words in the string, I only know the position of the word I want.
I know it should be easy, but I couldn't do it without problems with pointers and other strange things.
What's is the standard way to do it?. Some code would be fantastic.
Thanks and regards.
I mean:
String_1= "three"
Thanks and regards.
beginning from the end of "String" look for a blank.
Then you get the position of the last word.
Now you can extract the two substrings using strcpy() and strncpy()
Try this code. Maybe you must modify it a little bit, I've written it "from brain to keyboard" and didn't test it.
But it should show the idea.
void Split (char *string, char *part1, char *part2)
int i;
int len = strlen(string);
for (i=len-1; i>=0 && i!=' '; i--)
if (i >= 0) // found a blank
strncpy(part1, string, i);
part1[i] = 0;
strncpy(part2, &string[i+1], len-i);
part2[len-i] = 0;
else
part1[0] = 0;
part2[0] = 0;
int i;
part1[i] = 0;
part2[len-i] = 0;
else
part1[0] = 0;
part2[0] = 0;
Change
strcat ( pszOutBuff
strcat ( pszOutBuff
pc = strtok ( NU
to read
strcat ( pszOutBuff
pc = strtok ( NU
if ( pc)
strcat ( pszOutBuff
