Solved
Historial configuration on IE5
Posted on 2000-04-28
7
Last Modified: 2013-12-28
In my Internrnet Explorer 5, when I activate the historial window, I see all pages visited in alphabetical order, instead of date and time order. How can I change it, so I can see it date and time ordered ?
Question by:mito57
  • 3
  • 3
7 Comments
LVL 12
Expert Comment
by:pjknibbs
Select the View menu at the top of the History window and select By Date.
LVL 1
Expert Comment
by:Vinay
oh its easy mito...... just click the view button on left top of history window & u have options that u can change accordingly......
Vinay
LVL 12
Expert Comment
by:pjknibbs
Nice one, Vinay. Duplicate a comment somebody made more than two hours before you came along, but submit it as an answer...must have taken some real genius to do that.
We value your feedback.
Author Comment
by:mito57
Adjusted points from 200 to 250
Author Comment
by:mito57
I don't have a menu in my historial window. First, you have to tell me how to activate the menu.
LVL 12
Accepted Solution
by:
pjknibbs earned 750 total points
As far as I know there's no way to turn that menu off. The History folder on my copy of IE5 once went on the fritz and lost its menu--I had to reinstall IE5 to fix it.
Author Comment
by:mito57
I've reinstaled IE5, and now I have the historial window menu.
Most folks would know the basics of how Dropbox works, so that’s not the purpose of this article. Security is what it’s all about, so here I’ll share how I choose to secure my Dropbox Account and the Data it contains.
A few solutions to a problem some of us have been having when trying to add Hostgator email accounts to Outlook 2016 (will probably work with Outlook 2013 as well).
This Micro Tutorial hows how you can integrate  Mac OSX to a Windows Active Directory Domain. Apple has made it easy to allow users to bind their macs to a windows domain with relative ease. The following video show how to bind OSX Mavericks to …
This is used to tweak the memory usage for your computer, it is used for servers more so than workstations but just be careful editing registry settings as it may cause irreversible results. I hold no responsibility for anything you do to the regist…
609 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
