csindorf
3d parts model
I am working on some graphics stuff and need a free 3d model of some kind of part that I can use as a test subject. Do you know any places on the web I might fine one? That way I do not need to go into a cad program and make one.
Craig
Craig
There are loads of places on the net, but you need to be a little more specific.
www.3dcafe.com is quite good
www.3dtotal.com
Those are the two I think are best, but i prefer to do stuff myself.
What program are you using, is it an art package like 3d studio Max, or a CAD program.
I only know the Arty stuff so will not be able to help otherwise
www.3dtotal.com
What object format are you looking for?
Thanks all of you
I can provide IGES, STEP, VRML, ACIS, SAT or SolidDesigner native format.
Let me know, and I will send you something via e-mail.
John
