sound quality problem
I am very new to flash.  I imported a sound file (wav). When I play the wav file under flash (Window - library - wavefile.wav - play) it plays the file in good quality but after I publish it, i start to hear some disturbance in the sound (something like clicks).  I tried to test the published flash animation on other PC's but the same results.  Any suggestions ????
ssdesignConnect With a Mentor Commented:
You can go to file- publish settings
Click the flash button and here set the mp3 quality higher.
This should solve the problem
The wav file is converted to MP3.
If you go to - file - export movie. Enter the name of the file.
After this you get a screen where you can change the compression amounts of the audio clips.
If you try setting the kps to something higher then the compression will decrease (larger file) and the quality will increase.
hope this helps
