Solved
j323 engine sound problem
Posted on 2001-06-02
Last Modified: 2008-03-03
hi,
i am using j323 engine to communicate between two applications running on two different machines using jtapi (java telephony api) but i am unable to hear any sound, neither the person at the other end is able to hear any sound. The programs that i am using are the sample programs from 'Sun' called Incall.java and Outcall.java. I have made all the necessary modifications to the programs to make it work with the j323 engine.
I am working on linux.
I have JMF installed in both machines involved
I am calling the method 'getProvider()'in the following way                                      'myprovider.getProvider("H.323_Endpoint;login=najeeb.ahmed;h323.endpoint.signaling.port=49150;jmf.package=com.ibm.media.teljmf.TjTmProvider
I have read in the j323 documentation that the jmf based media subsystem plugin should handle all the streaming of media (sound). So what do i have to do? Do I need to add the streaming code in the above mentioned programs
if any one has any answer, please reply soon.
thanks
Najeeb ahmed
Question by:najeeb_a_99
3 Comments
LVL 3
Expert Comment
by:exorcist
do you have the JMF installed properly? Try to run JMStudio to test this.
second, if you are using Linux you won't ever hear sound since J323 is not properly implemented to record sound on Linux.
third, trying to play sound from a file or recording it, won't work either since this part of JTAPI is not implemented in J323. (For no known reason).
the java exorcist.
LVL 5
Expert Comment
by:vemul
I will leave a recommendation in the Cleanup topic area that this question is:
- To be PAQ'ed and points NOT refunded
Please leave any comments here within the
next seven days.
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER !
vemul
Cleanup Volunteer
Accepted Solution
by:
Banath earned 0 total points
Per recommendation - PAQ'ed and points NOT refunded
Banath
EE Moderator
Free Tool: Port Scanner
Check which ports are open to the outside world. Helps make sure that your firewall rules are working as intended.
Join & Write a Comment
Java functions are among the best things for programmers to work with as Java sites can be very easy to read and prepare. Java especially simplifies many processes in the coding industry as it helps integrate many forms of technology and different d…
In this post we will learn how to make Android Gesture Tutorial and give different functionality whenever a user Touch or Scroll android screen.
Viewers will learn about basic arrays, how to declare them, and how to use them. Introduction and definition: Declare an array and cover the syntax of declaring them: Initialize every index in the created array: Example/Features of a basic arr…
The viewer will learn how to implement Singleton Design Pattern in Java.
595 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
