need help for workflow architect
hello,
 i am working in workflow architect.i create one activity for that i gave the basic properties owner and form .and i created one automated activity for that i gave the sendto and subject and body.when i initiate the process after 10 minutes i am getting the error like this.
can anybody help me.
Job 'newvacation' ( NEWVACATION ) has caused the following error:
Can't expand participant rahamatulla@shaik.com .
No participants, including substitutes, are currently available: rahamatulla@shaik.com
No recipients found for the automated mail.
You will find the corresponding binder here: QualityApplicationWorkflow
Binder Cover:               URL:          http://shaik/QualityA.nsf/OSA/63091FEBE9C92AE143256A6D004080CD?OpenDocument
Main document:            URL:          http://shaik/QualityA.nsf/OSA/ADB38703050CB7F943256A6D00408024?OpenDocument
Database:               URL:          http://shaik/QualityA.nsf?OpenDatabase
saleemkhan
saleemkhan
ghassan99Commented:
Hi Saleem,
DWF is very strict in these things, it will try to look for the user in the Organization Directory.  Every user you want to try and send an email to must be listed in the OD, the mail address must be like this "Jon Doe/ABC@ABC".  For users not listed in the OD, you have to add "@ExternalAddress" to the email address.
Here is a tip to help you debug faster:
Make the agent "OS Domino Workflow Backgrounder" (in the applications database) run as 'Manually from Actions menu', then you can just launch the agent as soon as you complete the job, and you dont have to wait for 10 mins.
-Gus
saleemkhanAuthor Commented:
Thank u very much Ghassan.your comment helped me a lot.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
