tonylak
Remote Connection Problem to Oracle, Err Msg ORA-12535
I need a remote ODBC connection to my oracle database through a dialup line. Connection to database works fine on the LAN setup, but switched to Dialup Mode, It does not work. I created different Net Service Names for LAN and Dialup setup with their corresponding IP addresses.
The error encountered was ORA-12535: TNS Operation Time out. Is there additional setting required? What can be the cause of the problem? please help
tony.
tony.
Sometimes firewall problems cause timeout errors. If increasing connect_timeout doesn't help, maybe your dialup connection is outside the firewall. Check with your network people.
Hi tonylak,
It appears that you have forgotten this question. I will ask Community Support to close it unless you finalize it within 7 days. If there is no objection or further activity, I will suggest to:
Split points between: pbybee and catherinedevlin
tonylak, if you think your question was not answered at all or if you need help, you can simply post a new comment here. Community Support moderators will followup.
Please do not accept this comment as an answer!
EXPERTS: Your input for closing recommendations are REQUESTED.
DanRollins -- EE database cleanup volunteer
Finalized today. Points split.
Points for catherinedevlin -> https://www.experts-exchange.com/jsp/qShow.jsp?qid=20313348
Thanks for your help here, Dan.
Moondancer - EE Moderator
