omerfarooque
Filenet's Workflo 16 bit document entry class controls - need equivalent thrid part 32 bit controls
I am working on a conversion project of Filenet's workflo from 16 bit(4.16) to 32 bit(5.02). I am looking for some documentation of batching and indexing done in 32 bit version of this software. There are a few document
entry controls that are not available in the 32 bit version. I am looking for possible solutions for this.
Regards
Omer
P.S. Anyone worked on Filenet application - please let me know.
after some painful research -->
Here is what i know, from a some documentation that I could find for FileNet's document entry class of controls
of Filenet. They have stopped upgrades for this since they came out with the 32 bit version of the imaging
software called worklfo 5.03. I assume they let their clients rely on third party controls for document
entry operation. This involves controls that can recieve data from a scanner and arranging that in a
format that is comprehensible by Workflo 5.03. I have been looking for third party vendors for this.
IF ANY ONE HAS ANY POINTERS ON THIS, LET ME KNOW
Regards
Omer
I dont have any literature on workflo, we are currently in the proposal stage, any documentation would be really helpful.
Where are you?
Where are you?
Ok here is what i know, from a some documentation that I could find for document entry class of controls of Filenet. They have stopped upgrades for this since they came out with the 32 bit version of the imaging software called worklfo 5.03. I assume they let their clients rely on third party controls for document entry operation. This involves controls that can recieve data from a scanner and arranging that in a format that is comprehensible by Workflo 5.03. I have been looking for third party vendors for this.
There is no need to go thrid party controls.
We have successfully implemented 5.03 controls.
But i am not an expert in this field.
Suresh
Suresh
Hi omerfarooque,
It appears that you have forgotten this question. I will ask Community Support to close it unless you finalize it within 7 days. I will ask a Community Support Moderator to:
Accept sureshpodaralla's comment(s) as an answer.
omerfarooque, if you think your question was not answered at all or if you need help, just post a new comment here; Community Support will help you. DO NOT accept this comment as an answer.
EXPERTS: If you disagree with that recommendation, please post an explanatory comment.
DanRollins -- EE database cleanup volunteer
The information you gave was pertinent, but it didnt solve the problem as I had stated earlier the controls (16 bit) were converted to 32 bit but they werent OCx's and Filenet was unwilling to give us the ocx version of the components.
In the end we switched to the new IDM, so everything worked out fine.
Later
Omer
Later
Omer
see under document entry section.
You can find how to index and commit the batches.
If you dont have that book let me know.
I can send you some examples from that book
Suresh
