Frustrating FTP auto-capitalization problem please help
I have been trying for the past week to get my FTP problem solved. Problem is below:
I have created an application that logs on to a UNIX system via FTP. However when I use the command:
INET1.execute , "MKDIR chris",
A directory is created with the name if CHRIS. In other words the directory name is always in all caps no matter what I type in. This also occurs with the put command. If I type,
INET1.execute, "put test.tbb test.tbb", a file named TEST.TBB is created in the UNIX directory.
I need to be able to copy the files EXACTUALLY as I type them in the execute statement, because other they will not run in my employer's UNIX programs.
Would someone please please please tell me how to prevent it from capitilizing my filenames? Thanks. Please replay with the answer and also, send your replies to Chris.Johnson@bellsouth.com. Thanks!!!!
WdnUlik2noAsked:
Anthony PerkinsConnect With a Mentor Commented:
This works fine for me:
With Inet1
   .URL = "FTP site goes here"
   .Username = "username goes here"
   .Password = "password goes here"
   .Execute , "MKDIR Test"
   Do While .StillExecuting
      DoEvents
   Loop
   .Execute , "MKDIR TeSt"
      DoEvents
   Loop
End With
In other words it creates two distinct directories on a UNIX box.
You can also try using the following WiniInet API to see if you get the same result (I suspect you will):
Private Declare Function InternetOpen Lib "Wininet.dll" Alias "InternetOpenA" (ByVal lpszAgent As String, ByVal dwAccessType As Long, ByVal lpszProxyName As String, ByVal lpszProxyBypass As String, ByVal dwFlags As Long) As Long
Private Declare Function InternetConnect Lib "Wininet.dll" Alias "InternetConnectA" (ByVal hInternet As Long, ByVal lpszServerName As String, ByVal nServerPort As Long, ByVal lpszUserName As String, ByVal lpszPassword As String, ByVal dwService As Long, ByVal dwFlags As Long, ByVal dwContext As Long) As Long
Private Declare Function InternetCloseHandle Lib "Wininet.dll" (ByVal hEnumHandle As Long) As Long
Private Declare Function FtpCreateDirectory Lib "Wininet.dll" Alias "FtpCreateDirectoryA" (ByVal hConnect As Long, ByVal lpszDirectory As String) As Boolean
Public Sub Test()
Const INTERNET_SERVICE_FTP = 1
Const INTERNET_FLAG_EXISTING_CONNECT = &H20000000
Const INTERNET_FLAG_NO_CACHE_WRITE = &H4000000
Const INTERNET_OPEN_TYPE_DIRECT = 1
Const INTERNET_DEFAULT_FTP_PORT = 21
Dim hInternet As Long
Dim hConnect As Long
Dim Host As String
Dim Username As String
Dim Password As String
Dim Directory As String
Host = "FTP site goes here"
Username = "username"
Password = "password"
Directory = "TeSt"
hInternet = InternetOpen(App.EXEName, INTERNET_OPEN_TYPE_DIRECT, vbNullString, vbNullString, INTERNET_FLAG_NO_CACHE_WRITE)
If hInternet = 0 Then
   MsgBox "Error: " & CStr(Err.LastDllError), vbCritical, "InternetOpen"
Else
   hConnect = InternetConnect(hInternet, _
                                             Host, _
                                             INTERNET_DEFAULT_FTP_PORT, _
                                             Username, _
                                             Password, _
                                             INTERNET_SERVICE_FTP, _
                                             INTERNET_FLAG_EXISTING_CONNECT, &H0)
   If hConnect = 0 Then
      MsgBox "Error: " & CStr(Err.LastDllError), vbCritical, "InternetConnect"
   Else
      If FtpCreateDirectory(hConnect, Directory) = 0 Then
         MsgBox "Error: " & CStr(Err.LastDllError), vbCritical, "FtpCreateDirectory"
      End If
      InternetCloseHandle hConnect
   End If
   InternetCloseHandle hInternet
End If
End Sub
Anthony
Richie_SimonettiIT OperationsCommented:
It appears to be a problem with UNIX Server cfg.
WdnUlik2noAuthor Commented:
Nah its not that, because if I physically log in to the UNIX server I am able to create directories and get files exactually as I type them.  Also if I ftp in UNIX from DOS, I am also able to create directories and get files exactually as I type them.  It seems like the problem is the way the Internet Transfer Control is setup.  Maybe I have to set an option or something, Im not sure.
DanRollinsCommented:
Hi WdnUlik2no@devx,
It appears that you have forgotten this question. I will ask Community Support to close it unless you finalize it within 7 days. I will ask a Community Support Moderator to:
    Accept acperkins@devx's comment(s) as an answer.
WdnUlik2no@devx, if you think your question was not answered at all or if you need help, just post a new comment here; Community Support will help you.  DO NOT accept this comment as an answer.
EXPERTS: If you disagree with that recommendation, please post an explanatory comment.
DanRollins -- EE database cleanup volunteer
NetminderCommented:
Per recommendation, force-accepted.
Netminder
CS Moderator
