How to connect Lan using USB port instead of normal lan card?
May020698
May020698 asked
on
Is there a way to use USB port to connect a lan instead of lan card?
Watch Question
they are not common, but Linksys makes such an adapter. (USB100TX) Like most USB devices, they only work with win98, 2000, and ME.
There may be others, if so they all likely have the same limiations.
Mike
Top Expert 2004
you have this twice, delete one of them.
Now as far as the answer you may check out  www.laplink.com
and
http://www.laplink.com/support/updates/usbwin98.asp
you will need their special cable
May,
No comment has been added lately (686 days), so it's time to clean up this TA.
I will leave a recommendation in the Cleanup topic area for this question:
RECOMMENDATION: Award points to mpltech http:#6496781
Please leave any comments here within 7 days.
-- Please DO NOT accept this comment as an answer ! --
scott_renton
EE Cleanup Volunteer
Explore More ContentExplore courses, solutions, and other research materials related to this topic.
