djdidge
problem with my sql? error: "SQL command not properly ended"
I built a query in Access2000 and have been trying to get it to work in VB. I recieve an oracle driver error error: "SQL command not properly ended". Can anyone help?... All relevant code is below:-
Set connFOL = CreateObject("ADODB.Connec tion")
Set rsFOL = CreateObject("ADODB.Record set")
FOL = "Provider=MSDASQL.1;Persis t Security Info=False;User ID=XXXX;Password=XXXX;Data Source=FOL;Mode=Read"
connFOL.Open FOL
searchSQL = "SELECT STUDY_BLOCK_ASSOCIATIONS.S BA_SB_REF, STUDY_BLOCK_ASSOCIATIONS.S BA_MAIN_AC TIVITY, " _
& "STUDY_BLOCK_ASSOCIATIONS. SBA_SA_USE R_TEXT_3, STUDY_BLOCK_ASSOCIATIONS.S BA_SA_USER _TEXT_4, " _
& "STUDY_BLOCK_ASSOCIATIONS. SBA_TYPE, STUDY_BLOCK_ASSOCIATIONS.S BA_CALP_PE RIOD_CODE FROM STUDY_BLOCK_ASSOCIATIONS INNER JOIN STUDENTS ON STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF WHERE (((STUDY_BLOCK_ASSOCIATION S.SBA_SB_R EF)='GNVQ2 A&D') AND ((STUDENTS.S_REF)='9900075 6'));"
rsFOL.ActiveConnection = connFOL
rsFOL.Source = searchSQL
rsFOL.CursorType = adOpenStatic
rsFOL.CursorLocation = adUseClient
rsFOL.LockType = 3
rsFOL.Open
connFOL.Open FOL
rsFOL.LockType = 3
rsFOL.Open
Lose the ; at then end :- ));" should be ))"
No change :o(
i'll post the SQL again coz its a bit messed up above
searchSQL = "SELECT STUDY_BLOCK_ASSOCIATIONS.S BA_SB_REF, STUDY_BLOCK_ASSOCIATIONS.S BA_MAIN_AC TIVITY, STUDY_BLOCK_ASSOCIATIONS.S BA_SA_USER _TEXT_3, STUDY_BLOCK_ASSOCIATIONS.S BA_SA_USER _TEXT_4, STUDY_BLOCK_ASSOCIATIONS.S BA_TYPE,
STUDY_BLOCK_ASSOCIATIONS.S BA_CALP_PE RIOD_CODE FROM STUDY_BLOCK_ASSOCIATIONS INNER JOIN STUDENTS ON STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF WHERE (((STUDY_BLOCK_ASSOCIATION S.SBA_SB_R EF)='GNVQ2 A&D') AND ((STUDENTS.S_REF)='9900075 6'))"
Oracle is a black-hole to me.
However, is "&" a reserved character in Oracle?
If so, make it && instead of &.
I also believe that the semicolon (;) is required at the end, if it is a Oracle query.
i've not used & in my query...that was line breaking in VB...sorry for the confusion
Have you forget a the ')' at the end of the statement ?!
WHERE (
(STUDY_BLOCK_ASSOCIATIONS. SBA_SB_REF )='GNVQ2A& D'
AND (
(STUDENTS.S_REF)='99000756 ')
should be:
WHERE (
AND (
therefore your line is:
AND ((STUDENTS.S_REF)='9900075 6')));"
Best regards
;<)WoK
WHERE (
AND (
should be:
WHERE (
AND (
Best regards
;<)WoK
Forgive me for this but there is a & in 'GNVQ2A&D'.
To the best of my knowledge, Oracle does look into your values too for the reservered characters and creates problems if they are there.
Change this line in UR code
to
FOL = "Provider=MSDASQL.1;Persis t Security Info=False;UID=XXXX;PWD=XX XX;Data Source=FOL;Mode=Read"
to
:o( no joy
hi
The problem is that your SQL statement is on a single line. With the single line i mean that the SQL String is 455 chars long with no crlf caracter in it...
Change your VB code like this:
searchSQL = "SELECT STUDY_BLOCK_ASSOCIATIONS.S BA_SB_REF, " _
& " STUDY_BLOCK_ASSOCIATIONS.S BA_MAIN_AC TIVITY, " _
& " STUDY_BLOCK_ASSOCIATIONS.S BA_SA_USER _TEXT_3, " _
& " STUDY_BLOCK_ASSOCIATIONS.S BA_SA_USER _TEXT_4, " _
& " STUDY_BLOCK_ASSOCIATIONS.S BA_TYPE, " _
& " STUDY_BLOCK_ASSOCIATIONS.S BA_CALP_PE RIOD_CODE " _
& vbcrlf _
& " FROM STUDY_BLOCK_ASSOCIATIONS INNER JOIN STUDENTS " _
& " ON STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF " _
& " WHERE (((STUDY_BLOCK_ASSOCIATION S.SBA_SB_R EF)='GNVQ2 AD') " _
& " AND ((STUDENTS.S_REF)='9900075 6'))"
The number of ( and ) is correct...
Cheers
& vbcrlf _
Cheers
This makes it also more readable :-)
:o( no joy
even when I reduce the complexity of the code (to get some sort of result) the error persits.
& vbcrlf _
& " ON STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF;"
& vbcrlf _
the full error:
Runtime Error '-2147467259 (80004005)':
[Oracle][ODBC][Ora]ORA-009 33: SQL command not properly ended
and without the ; and maybe another crlf after 3 columns...
01. I know there will be a different type of error because of this mistake, but could you please modify your following code (if you don't mind) from:
To
Set rsFOL.ActiveConnection = connFOL
02. Have you tried running the resulted query string (searchSQL) in Oracle environment directly?
This will tell you if there is really an issue with query itself or something else.
To
Does Oracle supports this syntax of INNER JOIN ? You should try:
& " FROM STUDY_BLOCK_ASSOCIATIONS, STUDENTS " _
& "WHERE STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF;"
NitinSontakke there was no different error when i changed
To
Emoreau - just checking!
To
this is what i have at the moment, I think that the inner join idea may well be correct. But it doesn't run yet
& vbCrLf _
& " WHERE STUDY_BLOCK_ASSOCIATIONS.S BA_S_REF = STUDENTS.S_REF " _
& " AND (((STUDY_BLOCK_ASSOCIATION S.SBA_SB_R EF)='GNVQ2 AD') " _
& " AND ((STUDENTS.S_REF)='9900075 6')));"
& vbCrLf _
Please read ASP as your client application which could be VB desktop app, ASP, or any such thing.
As emoreau has pointed out Oracle does not support the Inner Join syntax.
Anthony
Anthony
Your last version (comment of 6:41 AM PST) _does_ have a ')' to much. Remove the last one, before the ';'
ok...now don't I feel like an idiot!.. I don't know the database that well so i was following some querys written by co-workers to formulate this problem query...however I have taken a better look at the structure of the db and now believe that i don't need the join... ie I only need 1 table.
The only question is who deserves the points?... (can't wait for the new point distribution facility from EE!)
Thanks all.
Discuss!
Thanks all.
Discuss!
This also confirms what i keep telling myself again and again.
"If it is going wrong, don't assume ANYTHING. Check EVERYTHING that is involved."
I am interested in knowing only one thing, is your problem solved?
If Yes, i can peacefully, "Unsubscribe" to this question.
Thanks for your help NitinSontakke, I have learned something from your posts.
My problem is solved thanks!
I'm giving you the points NitinSontakke, after reviewing the comments you seemed to off the most suggestions
Thanks "djdidge"!
That was totally unexpected, especially with my knowledge of Oracle.
As said above, i had unsubscribed to this thread already and was surprised to see the mail in my inbox with the same subject.
Thanks again.
Thanks again.
it was more of a computing fundamental that your expressed onto me....look hard and deep before asking people!
