Sound Problem????? Plz Help
Dear All,
I dont have very good experience in how to deal with sound in Java!!!
I want to ask if there is a method that can convert any sound file to the internal representation which is a number?
Any sample of code or comment will be very helpful.
Please help.
Thanx in advance.
Check out the "JavaSound API Programmer's Guide" from Sun at http://java.sun.com/j2se/1.4/docs/guide/sound/programmer_guide/index.html
I have tried the examples and they all seem to work very efficiently.
samjavAuthor Commented:
Thank you triso.
Join & Write a Comment
Hire Technology Freelancers with Gigs
Work with freelancers specializing in everything from database administration to programming, who have proven themselves as experts in their field. Hire the best, collaborate easily, pay securely, and get projects done right.
