fabiopb
Processor temperature, cooler speed and ACPI
Hi folks, I need some help here:
I read that my motherboard (Intel´s cc820) is capable of reading some data from the hardware, such processor´s temperature and cooler speed (RPM). How can I access this data? do I need especial extra hardware? or any extra software?
By the way: does it have anything to do with ACPI? for my coolers doesn´t go off when I put the computer to sleep.
Thanks!
A few notes: (thanks jlauster)
I´ve been visiting a lot of sites with technical information on the matter and it´s almost unbelievable how useless they are, especialy Intel´s site. Anyway, i took a look at the motherboard´s instalation CDrom and there´s no software to install wich could monitor the computer´s sensors.
I also searched for ACPI and I always find the same thing: "in order to use STR (suspend to ram) you must be sure your OS and your hardware is compatible with ACPI". How the f*ck am I gonna know that? (sorry for this) Couldn´t they just tell me how to find out!? Is windows 98 SE ok with ACPI? or a voodoo card?
Well, here are the facts:
- my computer has the option to "stand by", but not to "hibernate" (does that mean it´s ACPI enabled?)
- when it´s on stand by, the coolers won´t turn off (should it be like this?)
- i also read - in window´s help, just pressing F1 at desktop - that if you change you file system to FAT32 your system will automaticaly disable the "hibernate" mode, due to some incompatibility. Ever heard about it? (incredible how the newest technology in file system can´t live with the newest technology in computer stand-by. Congrats again, mr. Gates)
All I want is to have a computer that can suspend to ram and to find out the temperature of my processor. I think i´ll get nuts before that though.
Anyway, I apreciate your help A LOT. thanks, folks.
OS: windows 98 se
pentium III 600
128MB RAM
voodoo 3 3000
Thanks!
OS: windows 98 se
pentium III 600
128MB RAM
voodoo 3 3000
The monitoring should either be available in BIOS and setup there, or there will be a monitoring program on the motherboard installation CD. I'll see if I can find a bit more information on your board.
Check these FAQs for known problems and other info on your board.
http://search.intel.com/scripts/search/support/search.asp?q1=cc820&hidProductAlias=prd36&selFamily=All&isoCode=en&hidProductIndex=%2D1&selLine=All&SearchCrit=ALL&Category=support&MimeType=HTML&mh=200&recsPerPage=25&hidProductName=All+Products&Family=0&Line=All&RecordNum=1#ReviseSearch
** PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER **
It appears that this question has been abandoned. Please take a moment to finalize the question & reward your points as appropriate. If this question is not finalized within 7 days, Community Support will be requested to force close it. Unless there is objection or further activity, it will also be requested that points be awarded to the following expert(s) for their comments:
jlauster; t1n0m3n
If you feel that your question was not properly addressed, or that none of the comments received were appropriate answers, please post a request in Community support (with a link to this page) to refund your points. The link to the Community Support area is: https://www.experts-exchange.com/jsp/qList.jsp?ta=commspt
/EW
jlauster; t1n0m3n
/EW
Per recommendation, force-accepted.
Netminder
CS Moderator
Netminder
CS Moderator
jlauster: points for you at https://www.experts-exchange.com/jsp/qShow.jsp?ta=desktops&qid=20334309
Netminder
CS Moderator
Netminder
CS Moderator
