ximinez
Problem with graphics card/sound chipset
This is really driving me crazy. I got an ECS motherboard on VIA K7VZA chipset (with
integrated sound card), 256 SDRAM, AMD Athlon 1.2gHz, Daytona GeForce 2mx 32mb, Maxtor
40GB ATA/100 HDD all of this running under Win'98se. And this is the case - when I run a
game that requires Direct3d mode and in some cases OpenGL all goes smooth, but after a
while i get a high pitched noise and it hangs up. The same happens when i sometimes try to
play an mp3 file, and I have to play it first in KaZaA otherwise and error pops-up that
this format can't be played. I thought it was due to the graphics card drivers so I
updated them, no change.I think it's caused by the motherboard but maybe there is some
kind of a patch to solve this problem, because I can't have a second of entertainment on
my PC. Thanks in advance and sorry for my poor English.
If my suggestion solved your problem, why a B grade?
well i didn't solve it actually but it kind of delayed the time of hanging up. it still does, but i now know that it's caused by the built-in sound codec. Your advice still helped me, there's no doubt about it.
