azsoft
How to receive incoming calls using mscomm control
I'm using MSCOMM control for my dialer program.
the following is my vb settings:-
MSComm1.CommPort = 3
MSComm1.Settings = "9600,N,8,1"
MSComm1.InputLen = 0
MSComm1.RTSEnable = True 'must
MSComm1.PortOpen = True
this one is a call
MSComm1.Output = "ATDT" + Trim(Text1.Text) + Chr$(13)
and this is on my timer
If MSComm1.InBufferCount Then
MsgBox (MSComm1.Input)
End If
at this stage, i can call any phone number and also can send & receive msg to & from other party.
but when other party call my program, i don't know how to pickup or receive the call. for a start can somebody show how to pop up a message when there is a incoming calls.
this one is a call
End If
Where can i get the ATA.
Hi azsoft,
It appears that you have forgotten this question. I will ask Community Support to close it unless you finalize it within 7 days. I will ask a Community Support Moderator to:
Accept vinnyd79's comment(s) as an answer.
azsoft, if you think your question was not answered at all or if you need help, just post a new comment here; Community Support will help you. DO NOT accept this comment as an answer.
EXPERTS: If you disagree with that recommendation, please post an explanatory comment.
DanRollins -- EE database cleanup volunteer
per recommendation
SpideyMod
Community Support Moderator @Experts Exchange
SpideyMod
The MSCOMM Control raises events when ever anything happens on the COM port.
The Event is _OnCom
You have to detect a RING on the modem (comEvRing) and when it is received, you need to issues an ANSWER modem instruction (ATA).
If you set the RTThreshHold to 1 - an event will be raised everytime a character arrives on the port.
You can also use this to detect the 'RING' data arriving on the port and then handling the Ring.
I've had to do this on NT as NT has a problem raising the comEvRing event.
Once the modem answers the call you can change the RTThreshHold to a value that better suits you or even to 0 to prevent the raising of events.
HTH,
Alon
