amostcc
Help!!!Read data Problem
Hi again,
This time, I got myself into mess because I tried to write 20 numeric data into a text files and could not revive the values back into each textbox, I really need to get those values display onto each textbox. Can anyone help me?
Here somthing how I wrote the code
Open c:\temp for input as #1
write #1 form1.value1
write #1 form1.value2
write #1 form1.value3
close #1
(READ DATA)
open c:\temp as input as #1
input #1 myvalue <---- "not sure"
close #1
text1.text = myvalue <---
text2.text = myvalue <--- "how to read the second value from the wriiten data"??
close #1
(READ DATA)
close #1
Dim Temp as String
First of all to write data you have to open it for output
'Open c:\temp for input as #1
Open c:\temp for outputas #1
write #1, form1.value1
write #1, form1.value2
write #1, form1.value3
close #1
Second You need variable when you read data from text file
and do not forget to write comma after "input #1"
(READ DATA)
'open c:\temp as input as #1
open c:\temp for input as #1
input #1, Temp
Text1.Text = Temp
input #1, Temp
Text2.Text = Temp
close #1
(READ DATA)
input #1, Temp
Text1.Text = Temp
input #1, Temp
Text2.Text = Temp
I would suggest you to use File System Object Reference, so that the code is much more easier
If u want any reference i will give u the code
Good Luck...
Good Luck...
if your working with numbers you may want to get use to useing binary mode, and you should use the freefile function.
X = FreeFile
Open strFileName for binary as #X
Put #X, , intValue1
Put #X, , intValue2
Put #X, , lngValue3
Close #X
Then You can Get your Data Like This
X = FreeFile
if Len(X) > 0 then
Get #X, , intValue1
Get #X, , intValue2
Get #X, , lngValue3
End if
Close #X
Text1.Text = Value1
just be bewear doing this, if you save the dat useing a int then you have to load it with an int. also you may notice in the Get and Put functions the Get #X, , IntValue
theres nothing in the middle, you set the location in the file to store the value ex:
dim intMyVal as int
intMyVal = 12
Put #X, 50, intMyVal
Get #X, 50, intMyVal
you should get intMyVal to = 12
X = FreeFile
Put #X, , intValue1
Put #X, , intValue2
Put #X, , lngValue3
Close #X
X = FreeFile
if Len(X) > 0 then
Get #X, , intValue1
Get #X, , intValue2
Get #X, , lngValue3
End if
Close #X
Text1.Text = Value1
dim intMyVal as int
intMyVal = 12
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER!
I will leave a recommendation in Community Support that this question is:
- award the points to willisp
Please leave any comments here within the
next seven days.
next seven days.
Per recommendation, force-accepted.
Netminder
EE Admin
Netminder
EE Admin
Private Sub cmdRead_Click()
Dim lFreeFile As Long
lFreeFile = FreeFile
Open "c:\temp.dat" For Input As #lFreeFile
Dim sText1Val As String
Dim sText2Val As String
Input #lFreeFile, sText1Val, sText2Val
Text1.Text = sText1Val
Text2.Text = sText2Val
Close #lFreeFile
End Sub
Private Sub cmdWrite_Click()
Open "c:\temp.dat" For Output As #lFreeFile
Write #lFreeFile, Form1.Text1.Text, Form1.Text2.Text
Close #lFreeFile
End Sub
NOTE: In both the examples listed here, if the textbox contains one or more double-quotes ("), these techniques will not work. You will need to switch to the Print function instead of Write. In that case that you must allow double-quotes, willisp's code will be much easier to convert.
