FTP using PL/SQL and call PL/SQL procedure from UNIX
How can I call a PL/SQL procedure from a UNIX script?
And it can be done at a scheduled time?
Can I send a file using FTP from a PL/SQL procedure?, if not how can I do it with a UNIX script?
Thanks in advance!
marchmx
marchmx
stemu2000Commented:
benpungCommented:
below is an example of a shell script that calls pl/sql procedures and scripts. this is done at a scheduled time by using the crontab on the unix server to initiate this shell script, which in turn calls the procedures. hope this helps some.
# . /oracle/local/scripts/oracle.kshrc needs to be ran in order
# for the SQL code to be understood.
# Environment variables
DBINSTANCE=dev
LOGON_NAME=mylogon
LOGON_PASSWD=mypassword
XML_DIR="/home/ehsitdev"
# Change directory to the xml directory
cd $XML_DIR
# Connect to Oracle database
inst $DBINSTANCE
# Start sqlplus, log in to database, and initiate error log file
sqlplus -s $LOGON_NAME/$LOGON_PASSWD << SQLCMDS
     SET heading off
     SET termout on
     SET trimspool on
     SET feedback off
     SET serveroutput on
select to_char(sysdate, 'Dy DD-Mon-YYYY HH24:MI:SS') as "Process Start Time" from dual;
EXEC setMaxMemorySize_proc(200000000);
COMMIT;
EXEC bo_material_proc;
EXEC transform_expression_proc;
COMMIT;
@$HOME/insert_to_tmp.sql
COMMIT;
EXEC get_tmp_record_proc;
@$HOME/update_picklist.sql
@$HOME/update_op_uom.sql
COMMIT;
select to_char(sysdate, 'Dy DD-Mon-YYYY HH24:MI:SS') as "Process End Time" from dual;
EXIT
SQLCMDS
Helena Markováprogrammer-analystCommented:
I will leave a recommendation in the Cleanup topic area that this question is:
Accept benpung's comment as answer.
Please leave any comments here within the next seven days.
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER!
Henka
EE Cleanup Volunteer
We value your feedback.
