Solved
sound problem : comes and goes
Posted on 2003-03-06
5
Last Modified: 2008-02-26
i have a problem with the sound on my pc. when i first bought my pc it worked fine but for some reason (and usually when i am online) it just cuts out. i could be viewing a site, listening to a cd or playing an online game when it stops working.  then as i shut down my pc or restart i hear the 'exit windows' sound so it seems to work again.  when i turn the pc back on everything is fine.
i am running xp.  my hardware is: 1.2 Ghz duron, 256 ddr ram, ga-7vkml motherboard (which has ac97 codec sound on-board).
i have tried a clean install of xp and the problem still occurs.  i have heard ac97 is pretty crappy so do you think that is the problem or could it be something else.
thanks
Question by:tmoyn
  • 3
5 Comments
LVL 6
Expert Comment
by:henryww
get a new sound card will definitely solve the problem ... ! check if u can get a updated software driver for the ac97 ... and yes ... ac97 is crap ...
btw, this is the flash area :)
cheers
LVL 22
Expert Comment
by:rascalpants
this sounds like your computer has tried to use two different programs to open the same file at the same time...
and if this is a flash problem, then provide more detail...
rp
LVL 6
Accepted Solution
by:
henryww earned 400 total points
oh ... 1 thing u can try, ... change the IRQ & DMA for the rc97, ... it sounds like a DMA problem ... how many add-ons do u have?
Author Comment
by:tmoyn
thanks for your help henryww..... i will download the drivers and also check out the IRQ & DMA.
sorry about writing this in the flash area, it was my first time submitting a question so i wasn't paying enough attention.  i did submit my question in the 'hardware' area and got some good answers there too.
thanks again for your help... i appreciate it a lot.
terry
LVL 6
Expert Comment
by:henryww
u are welcome :)
let me know if the dma/irq do help with the problem.
cheers
Free Tool: Path Explorer
This is intended to introduce all collision detection principles in flash, their strengths, weaknesses and workarounds. The main method for Collision Detection in flash is using hitTestObject. But unless you'll be pushing rectangular shapes without …
This article describes a solution to a problem of subloading one movie into another when they have different SWF versions. Sometime back, I was working on an ActionScript project while I came across an interesting fact which I would like to share…
In this tutorial viewers will learn how to create a basic shape tween animation in Flash including shape hints for smooth animation Open a new document in Flash: Draw a shape: Select another frame (how long you want the tween to be): Right click and…
The goal of the tutorial is to teach the user how to select the video input device. Make sure you have an input device that in connected and work and recognized by Adobe Flash Media Live Encoder and select it in the “video input” menu.
Suggested Courses
Course of the Month12 days, 2 hours left to enroll
564 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
