stevesm
Need help with a shell script - FTP related
Here's my script, and here is the problem - the script is supposed to re-submit whatever is still missing (it could be 1 to 3 files). Currently the script is not working properly. In a few occasions when more than 1 edi files were missing, the scripts only managed to re-submit ONE file. What I would like to do is capture all the files (up to 3) when necessary. I need an explanation as to why this does not work and a solution to correct this problem. Don't worry about the path's names or passwords too much they have been edited.
myname=`basename $0`
mydate=`date +%Y%m%d`
ERROR_DIR=/tmp
if [ $# -eq 0 ]; then
SEND_HOST=192.168.106.12
SEND_USER=whatever
SEND_PASS=secret
SEND_DEST=/
DOWNDIR=/outbound
RETRDIR=/retrieve
echo "$mydate `date +%T`:**Processing for Primary System $OBJECT "
else
SEND_HOST=192.168.106.11
SEND_USER=whatever
SEND_PASS=secret
SEND_DEST=/
DOWNDIR=/outbound
RETRDIR=/retrieve
echo "$mydate `date +%T`:**Processing for Alternate System $OBJECT "
fi
ARCHIVEDIR=/processed
SYSDIR=/
ETCDIR=$SYSDIR/etc
# USERS=`cat $ETCDIR/Mail.notify`
shdirname()
expr \
${1-.}'/' : '\(/\)[^/]*//*$' \
\| ${1-.}'/' : '\(.*[^/]\)//*[^/][^/]*//* $' \
# Procedure used to send files
ftpfile()
echo "$mydate `date +%T`:$OBJECT:**Processing - Sending $OBJECT.req "
cp $RETRDIR/$OBJECT.edi $DOWNDIR/$OBJECT.req
/usr/bin/ftp -vin >$ERROR_DIR/$OBJECT.put.su mmary.$$ 2> /$ERROR_DIR/$OBJECT.put.ER RORS.$$ <<EOF
open $SEND_HOST
user $SEND_USER $SEND_PASS
binary
cd $SEND_DEST
put $OBJECT.req
bye
EOF
# Procedure may be used to check errors
ftpcheck()
WARNINGS=`grep '226 Transfer' /tmp/$OBJECT.put.summary.$ $ | wc -l`
if [ "$WARNINGS" -ne 1 ]; then
echo "$mydate `date +%T`:$OBJECT:**Ftp has encountered error.. Check $OBJECT.put.summary.$$"
fi
# Housekeeping...
housekeep()
echo "$mydate `date +%T`:$OBJECT:**Removing $OBJECT .."
rm $DOWNDIR/$OBJECT.[Rr][Ee][ Qq]
# Script stuff starts here....
echo "$mydate `date +%T`:**Starts .."
cd $RETRDIR
OBJECTS=`ls *.edi 2>/dev/null | awk -F\. '{ print $1 }' | sort -u | awk '{ printf " %s", $1 }'`
# anything to do ?
echo "$mydate `date +%T`:**Scanning for Files To Re-Send.."
if [ -z "$OBJECTS" ]; then
echo "$mydate `date +%T`:**No Files To Re-Send Ending..."
exit 1
fi
# walk the directory process available files....
for OBJECT in $OBJECTS;
do
TARGETS=`ls $OBJECT*`
cd $DOWNDIR
if [ ! -z "$TARGETS" ]; then
for TARGET in $TARGETS;
do
echo "$mydate `date +%T`:$OBJECT:**Processing File:$TARGET ..."
if [ "$TARGET" = "$OBJECT.ack" -o "$TARGET" = "$OBJECT.ACK" ]; then
echo "$mydate `date +%T`:$OBJECT:**Creating Retrieval Entry for File:$OBJECT.ACK ..."
touch $RETRDIR/$OBJECT.ACK
mv $TARGET $ARCHIVEDIR/$TARGET.$$
else
ftpfile
ftpcheck
housekeep
fi
done
fi
done
ERROR_DIR=/tmp
SEND_USER=whatever
SEND_PASS=secret
SEND_DEST=/
DOWNDIR=/outbound
RETRDIR=/retrieve
else
SEND_USER=whatever
SEND_PASS=secret
SEND_DEST=/
DOWNDIR=/outbound
RETRDIR=/retrieve
fi
SYSDIR=/
ETCDIR=$SYSDIR/etc
shdirname()
expr \
ftpfile()
open $SEND_HOST
binary
cd $SEND_DEST
put $OBJECT.req
bye
EOF
ftpcheck()
fi
# Housekeeping...
housekeep()
cd $RETRDIR
# anything to do ?
exit 1
fi
do
cd $DOWNDIR
do
else
ftpfile
ftpcheck
housekeep
fi
done
fi
done
My apologies for taking so long to get back, no excuses. I changed the variable as you mentioned and it worked like a charm.
Thanks for your help
Steve
Steve
Cheers
