Solved
Problem with color conversion
Posted on 2003-03-14
5
Last Modified: 2010-04-04
I have make a little application that create a report as html format, and let some posibilities to customize the design.
So i need to have the hexadecimal value of color for html (background color for example).
How can I convert delphi's colors (clNavy, clRed, etc..) in TColor type to Hexadecimal ??
Thanks !
PS: Sorry for my english i'm french :-)
Question by:krypto2000
5 Comments
LVL 1
Expert Comment
by:SimesA
Use IntToHex(ColorToRGB(color),6);
LVL 9
Expert Comment
by:mocarts
function ColorToHTMLColor(const Value: TColor): string;
begin
  with TRGBQuad(Value) do
    Result := '#' + IntToHex((rgbBlue shl 16) + (rgbGreen shl 8) +  rgbRed, 6);
end;
wbr, mo.
LVL 1
Expert Comment
by:Svisj
hi try this!
function TColorToHex( Color : TColor ) : string;
function TForm1.TColorToHex( Color : TColor ) : string;
begin
  Result :=
    { red value }
    IntToHex( GetRValue( Color ), 2 ) +
    { green value }
    IntToHex( GetGValue( Color ), 2 ) +
    { blue value }
    IntToHex( GetBValue( Color ), 2 );
end;
//Eks edit1.Text := TColorToHex(clYellow);
LVL 6
Accepted Solution
by:
PoeticAudio earned 100 total points
Because an actual Hex conversion is different then HTML Hex you will have to switch things around  a little bit...
Function HexToHTMLhex (HEXColor: TColor): string;
var
  HexStr: String;
  rStr, mStr, lStr: String;
begin
  HexStr := IntToHex(HEXColor, 6);
  rStr := MidStr(HexStr, 5, 2);
  mStr := MidStr(HexStr, 3, 2);
  lStr := MidStr(HexStr, 1, 2);
  Result := rStr + mStr + lStr;
end;
LVL 9
Expert Comment
by:mocarts
hi, krypto :)
can you tell us why you accepted this answer? :) fully unoptimized and doing the same thing as my proposed answer? :)
wbr, mo.
[Webinar On Demand] Database Backup and Recovery
Does your company store data on premises, off site, in the cloud, or a combination of these? If you answered “yes”, you need a data backup recovery plan that fits each and every platform. Watch now as as Percona teaches us how to build agile data backup recovery plan.
Hello everybody This Article will show you how to validate number with TEdit control, What's the TEdit control? TEdit is a standard Windows edit control on a form, it allows to user to write, read and copy/paste single line of text. Usua…
This is an update to some code that someone else posted on Experts Exchange. It is an alternate approach, I think a little easier to use, & makes sure that things like the Task Bar will update.
This lesson discusses how to use a Mainform + Subforms in Microsoft Access to find and enter data for payments on orders. The sample data comes from a custom shop that builds and sells movable storage structures that are delivered to your property. …
As many of you are aware about Scanpst.exe utility which is owned by Microsoft itself to repair inaccessible or damaged PST files, but the question is do you really think Scanpst.exe is capable to repair all sorts of PST related corruption issues?
Suggested Courses
Course of the Month12 days, 23 hours left to enroll
580 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
