Solved
ODBC connection/authentication problem using ASP
Posted on 2003-03-27
15
Last Modified: 2012-05-04
I have created a database in SQL Server and am trying to connect to it via ODBC DSN. I have created a DSN and have set it to use Windows Authentication rather then SQL authentication.
I set the default database to one i created and test the connection. The Test proves successful.
I have setup IIS to also use Windows Authentication, and requests to ASPs in my application without database access work fine.
But when ever a page uses the connection string to access the database it reports:
"Invalid object Name 'accessRights'", where accessRights is the name of one of the tables.
I am using the following connection string to access the DSN connection:
strConn = "DSN=myDSN"
Set objConn = Server.CreateObject("ADOBD.Connection")
objConn.Open strConn
I then use a simple Select statement to retrieve a recordset, but i get the error message.
"SELECT * FROM accessRights;"
Can anyone help?
Question by:andichilds
  • 7
  • 4
  • 3
  • +1
15 Comments
LVL 4
Expert Comment
by:Wakie
Replace:
With:
Set objConn = Server.CreateObject("ADODB.Connection")
Author Comment
by:andichilds
Sorry, that was a typo. It is ADODB.Connection in the connection string.
LVL 6
Expert Comment
by:MannSoft
Does your DSN set a default database?  If not, you'll have to select one programatically before you can work with a table.
LVL 6
Expert Comment
by:MannSoft
You would do that with objConn.DefaultDatabase = "mydatabase" btw
Author Comment
by:andichilds
Author Comment
by:andichilds
I have been looking into the problem today and found that if you put 'dbo.' before the table name in the select statements it works. Is there a quick way of applying this to all the select statements?
LVL 6
Expert Comment
by:MannSoft
For simple selects you can just search and replace "FROM " with "FROM dbo.", but for complex selects from multiple tables, that will only work on the first table of course.  Not to mention the fact that if you have more than a handful of files you'll be opening and closing files all day :)
Author Comment
by:andichilds
Author Comment
by:andichilds
Author Comment
by:andichilds
Accepted Solution
by:
andichilds earned 0 total points
I have solved the problem.
There were two factors.
The first was that the network users had not been added to SQL Server roles datareader and datawriter.
The second, and i refer to, http://support.microsoft.com/support/kb/articles/Q279/5/26.ASP, reports a known problem problem with the SQL ODBC Driver.
LVL 4
Expert Comment
by:Wakie
How do you intend to close this question?
LVL 6
Expert Comment
by:MannSoft
In the future you may not want to hit refresh to see if there are new messages.  You were resubmitting the form data which is why you have the same post up there multiple times.
And since you solved it yourself, it seems like a good candidate for deletion.  You can ask them to do that in the Community Support forum.
LVL 58
Expert Comment
by:Gary
I will leave a recommendation in the Cleanup topic area that this question is:
PAQ'd and pts refunded
Please leave any comments here within the next seven days.
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER!
GaryC123
EE Cleanup Volunteer
We value your feedback.
Have you ever needed to get an ASP script to wait for a while? I have, just to let something else happen. Or in my case, to allow other stuff to happen while I was murdering my MySQL database with an update. The Original Issue This was written…
This demonstration started out as a follow up to some recently posted questions on the subject of logging in: http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_28634665.html and http://www.experts-exchange.com/Programming/…
This lesson discusses how to use a Mainform + Subforms in Microsoft Access to find and enter data for payments on orders. The sample data comes from a custom shop that builds and sells movable storage structures that are delivered to your property. …
Whether it be Exchange Server Crash Issues, Dirty Shutdown Errors or Failed to mount error, Stellar Phoenix Mailbox Exchange Recovery has always got your back. With the help of its easy to understand user interface and 3 simple steps recovery proced…
Suggested Courses
571 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
