HELP! I need an expert to help me display a splash page while macros are running
I have a few loops running and as the macro runs through the LOOOONG data, it can cause a little dizzyness.  Is there a way I can introduce a splash page that 'pops up' when The macro begins (maybe one that says loading) and disappears when the last macro is completed?
Dina-mic
Dina-mic
IeuanJCommented:
Create your splash form then just show/hide it as necessary.
Load Form2
Form2.Show
'do your macro stuff here
Form2.Hide
Unload Form2
Dina-micAuthor Commented:
The splash pages load but do NOT run at the same time as the macros... that's what I need
craigewensCommented:
Just put IeuanJ's code inside your macro modules then.
We value your feedback.
The problem still occurs... you have to manually shut down the splash page.  Optimally this would happen:
1.  Run the macro
2.  Splash page pops up and says "loading..."
3.  Macros run in the background
4.  Macros finish, splash disapears.
The splash is needed to take the user's eye away from the data scrolling in th backgroun (built into the macro itself)
YeaYuhCommented:
Personally I would just do an
Application.ScreenUpdating = False
this will prevent any changes from being shown on the screen, and will make the macro run faster
Then when the macro is done just do
Application.ScreenUpdating = True
You're a FRICKEN star!
IeuanJCommented:
I still dont see why my code doesnt work, just close the window as the last thing in your macro, it's not hard to work around.
