rukiman
search engine friendly script problem
I have written a search engine script using PHP ie accessing http://www.test.com/catalogue/chairs/a.html
calls a PHP script called "catalogue" that passes in the values "chairs" and "a.html". My script then goes into the directory "chairs/a.html" and spits out the information after inserting them into a template html page to make it fit the theme of my website. The problem is that paths all seem to be wrong and all the images and CSS style sheet links are invalid. If I just for debugging sake hardcoded "chairs" and "a.html" as parameters within the script then just called
everything is displayed correctly! so the "/chairs/a.html" appended after the url is causing the invalid paths. How can I fix this? I don't really want to make use of absolute paths in my theme page.
You should show us a bit of your code.
Don't forget that if you include some files in php, the path is relative to the main file...
For example:
your directory:
index.php
catalogue/chair.html
images/chair.png
index.php includes
and in chair.html you want to display:
images/chair.png
you'll have to use: <img src="images/chair.png" width=... /> and not <img src="../images/chair.png" width=... />
if that's not the point, post some code... we'll see !
For example:
your directory:
index.php
images/chair.png
index.php includes
images/chair.png
ok I dont have the code with me on this computer but hope this helps
a1.html has the following content
this is a test <img src="cat.jpg"></img> woo hoo
the catalogue PHP script is as follows
<?php
// get the directory and filename from the url as we are using GET
// $dir is the first input, $page is the second input
$basedir = "htmlcatalogue/";
$file = file( $basedir . $dir . "/" . $page);
<html>
<body>
ok lets see what we pulled out: <br>
<? php echo $file ?>
<img src="dog.jpg"></img>
</body>
</html>
and here is the directory structure
htmlcatalogue ------------------->adapt- ------->a1 .html
catalogue (php script)
the script is invoked as follows:
http://www.test.com/catalogue/adapt/a1.html
<?php
<html>
<body>
</body>
</html>
Do this: right-click on the broken 'cat' image and open it in a new window in your browser. Look for error messages. Also, look at the URL. The URL for the cat image is calling the catalogue php script. Simplest fix is to keep any images/external stylesheets/javascript stuff in a separate directory, and reference it using the complete URL.
<img src="http://www.test.com/images/cat.jpg" />
