low level hard drive help
KeaneE04
KeaneE04 used Ask the Experts™
on
Ok, first a quick background: I, along with a small group of diehards came up with a way to disable the EU volume cap protection on the european ipods.  Unfortunately, this way never caught on, as it is a VERY difficult process for people used to apple products to handle.
Now, to solve the problem, and possibly make it more mainstream, i would like to create a C++ (or java, altho i hate the language, i also know a little about it) application to accomplish the task for the user.
Herein lies the problem, i cannot for the life of me find any API or class file that will allow me to accomplish the specific tasks required.  I believe it would require Very Very low level hard drive access, and some way to determine which drive is the ipod on everyones computer (ipod is treated as a standard Hard Disk by linux, only as an SDA device, if that helps), and accomplish the following processes (first on the win 2k/xp platform, then possibly on the osx platform):
1) Completely repartition a hard drive, including hidden partitions.
The way the ipod is set up, there is 3 partitions, only 1 of which is viewable to the OS. AS read in osx
#:  type                  name          length         base     ( size
1:  Apple_partition_map partition map    62 @              1
2:  Apple_MDFW          firmware        81920 @       63       (
40.0M)
3:  Apple_HFS*          disk           29215536 @    81983    (
13.9G**)
Device block size=512, Number of Blocks=29215536 DeviceType=0x0, DeviceId=0x0
*can also be FAT32 for windows formatted ipods
** Can be anywhere from 10G(advertisers gb, not a real one, the 13.9 is supposedly a 15gb) worth, to now 40G worth.
The 3rd partition is unimportant at the moment, only the first 2.
2) Write back a firmware image onto the MDFW partition from a binary file previously captured.
Basically, what needs to be done is the MDFW partition needs to be resized from 32 mb to 40mb and a new firmware file written back to it.
If anyone has any information whatsoever on something that you think will help me with my task, i would be very gratefull.
Thank you all,
Erich Keane
PS, looking through the pages and pages here, i saw that perhaps createfile(\\.\PhysicalDrivex) might help me somewhat.  The OS is Windows 2000/XP only.
Watch Question
Do more with
Expert Office
Take a look at Microsoft SDK Floppy sample which can be found in Microsoft SDK\Samples\winbase\IO\Floppy directory.
Readme.txt from this sample
Accessing a Floppy Disk
SUMMARY
The FLOPPY sample is designed to show how to access a physical floppy disk
under Windows NT.
This program has two major features:
  - It can be used to display the geometry of a disk. For example, use the
    command:
        mfmt -g a:
  - It can be used to produce a disk image, or to write a disk image to a
    floppy. For example, use the commands:
        mfmt -c a: bootdisk         - produce a disk image of a:
        mfmt -c bootdisk a:         - make a: identical to bootdisk image
MORE INFORMATION
This program is very simple. Minimal error checking is done. It is meant to
provide an example of how to:
  - Open a physical disk.
  - Read a disk's geometry.
  - Perform a low-level format operation.
  - Read and write physical sectors.
The problem with this is that out of the 3 partitions, only 1 has a drive letter in windows, the rest are ignored by the OS, so i dont have direct access to the disk in that way.
This sample works with physical drive and not partitions.
Announcing the Winners!
The results are in for the 15th Annual Expert Awards! Congratulations to the winners, and thank you to everyone who participated in the nominations. We are so grateful for the valuable contributions experts make on a daily basis. Click to read more about this year’s recipients!
Thank you for your help so far, but im still not sure that I understand your recommendation.  I am using BloodShed Dev C++, so i dont have visual studio.  Do you know the web address for the document that you are speaking of, perhaps one with a method overview chart?
No comment has been added lately, so it's time to clean up this question.
I will leave the following recommendation for this question in the Cleanup topic area:
PAQ with points refunded
Please leave any comments here within the next four days.
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER!
Tinchos
EE Cleanup Volunteer
PAQed, with points refunded (125)
ee_ai_construct
Community Support Moderator
Do more with
Expert Office
Start 7-Day Free Trial
