Frank-22
MIME-parts and JavaMail
Hello
I'm doing an email client with JavaMail and I got a question regarding storing the email-messages.
I would like to write a modul called 'Store' for my program, that does the following.
1) Then this modul recieves an email it would like to split it up into MIME-parts (From, id, mailbody) etc. I would like these parts to be stored in a MySQLDB.
2) Is it possible to add feature that reassembles these MIME-parts into a readable email ?
I hope that there are someone of You, how can answer these questions for me !
Yours
Frank
Yours
Frank
Just look at the Part/MimePart interface. If you decompose the mail into its parts you can write it to a db, possibly with the assistance of serialization and ObjectOutputStream. Each Part should be renderable on the symmetrical read operation with ObjectInputStream.
Yeah,
I know I can do this to decode the message.
MimePart part = ...
String rawvalue = null;
String value = null;
try {
if ((rawvalue = part.getHeader("X-mailer") [0]) != null)
value = MimeUtility.decodeText(raw value);
} catch (UnsupportedEncodingExcept ion e) {
// Don't care
value = rawvalue;
} catch (MessagingException me) { }
return value;
But how do I save these MIME-parts into a MYSQLDB, and Reassemble them into an readable email ?
The reason for me asking is because I have looked through all the books I have at home for a method on how to do this, but have been unable to find any !!!
And I promissed someone, that I could do this easily and present a working modul tommorow !
So it would "really" appricate if You could show me how to do it !!
Frank
MimePart part = ...
try {
// Don't care
value = rawvalue;
return value;
Frank
Hi
As of now my Store-Modul looks the code below.
I'm uanable to get the store-feature to function.
What I'm I doing wrong ? How do I get it to work ?
Frank
package modmail.store;
import javax.mail.*;
import modmail.listener.*;
import java.sql.*;
public class mySQL implements GuiListener, ReceiveListener
private Connection connectionToDB;
private String password = "";
private String login = "";
private String selectDB = "";
//Start of RecieveListener's methods
public void saveSuccessful(boolean b, String[] arrayOfMailID, int errorcode)
public void hasNewMail(String[] arrayOfMailID)
//End of RecieveListener's methods
//Start of GuiListener's methods
/** Is activated when the button "Send" is pressed on the GUI. */
public void sendButtonClicked()
//Do nothing
public void reciveButtonClicked()
public void loadMail()
public void saveMail()
public void deleteMail()
public void undeleteMail()
public void printMail()
//Do nothing
//End of GuiListener's methods
private void connectToDb()
/** Temporaty code to login, get login info from config file later */
if(password == "" || login == "" || selectDB == "")
password = "e3110";
login = "root";
selectDB = "//localhost/movieDB";
try{
Class.forName("com.mysql.j dbc.Driver ").newInst ance();
connectionToDB = DriverManager.getConnectio n("jdbc:my sql:" + selectDB + "?user=" + login + "&password=" + password);
}catch(Exception e){}
/** Adds an email to the mail database. */
public void addEntry(Message mail) throws Exception
Statement stmt = null;
String query = "";
String subject = mail.getSubject();
Date sendDate = mail.getSendDate();
String fromEmail = (mail.getSender()).toStrin g();
Address[] replyToAdd = mail.getReplyTo();
String[] replyTo = new String[replyToAdd.length];
for(int i = 0; i > replyToAdd.length; i++)
replyTo[i] = replyToAdd.toString();
Date recievedDate = mail.getRecievedDate();
String body = ""; // WRU real body txt?!?
int ID = mail.getMessageID();
stmt = connectionToDB.createState ment();
stmt.executeUpdate(query);
stmt = null;
Frank
import java.sql.*;
//Do nothing
//Do nothing
password = "e3110";
login = "root";
try{
String query = "";
stmt = null;
And what seems to be the problem?
(almost) never have this sort of thing:
I get an unrecognized type every time I try to add !
Is there a better way of doing it than I'm allready doing it now ?
Sincerely
Frank
Sincerely
Frank
All I can see of your statement is the following:
>>String query = "";
What is it meant to be - what will your SQL be?
>>String query = "";
Hi and thank You for Your answer.
As You correctly singled out the String query = ""; is empty, that is because I can not get the sql query, that was suppose to insert the MiME-parts into the mySQL db.
I know how to make an sql - query, but unfornally not in this context.
So I would really appricate if You have a surgestion on how You think this SQL-Query should sound ?
Sincerely
Frank
Sincerely
Frank
The first thing you need to do is have a table with columns in it to take all the pieces of data you want to save. You would then do an INSERT statement
Okay....
I got a table called maildb (movieDB is a typoo) would this be a correct query ?
String query = "insert into maildb (subject, sendDate, fromEmail) values ('" + mail.getSubject() + "','" + mail.getSendDate() + "','" + (mail.getSender()).toStrin g() + "')";
Sincerely
Frank
Sincerely
Frank
