Solved
Problem with view.. need help ASAP
Posted on 2003-11-11
Last Modified: 2012-08-13
Here is my view...
--Begin View
Select Addresses.IDNumber, Addresses.AddressID,
      'OfficeID' =
            Case
                  When Addresses.IDNumber Between 1 and 999999 Then COffice.OfficeID
                  When Addresses.IDNumber > 999999 Then MOffice.OfficeID
            End,
      'OfficeName' =
            Case
                  When Addresses.IDNumber Between 1 and 999999 Then COffice.OfficeName
                  When Addresses.IDNumber > 999999 Then MOffice.OfficeName
            End,
      'OfficeLocation' =
            Case
                  When Addresses.IDNumber Between 1 and 999999 Then COffice.OfficeLocation
                  When Addresses.IDNumber > 999999 Then MOffice.OfficeLocation
            End,
      'MemberType' =
            Case
                  When Addresses.IDNumber Between 1 and 999999 Then Campgrounds.Account
                  When Addresses.IDNumber > 999999 Then Members.MemberType
            End,
      'Account' =
            Case
                  When Addresses.IDNumber > 999999 Then Members.Account
            End,
      'Name' =
            Case
                  When Addresses.IDNumber Between 1 and 999999 Then Campgrounds.Campground
                  When Addresses.IDNumber > 999999 Then Cast(Replace(RTrim(LTrim(Members.Title + ' ' + Members.Firstname + ' ' + Members.Middlename + ' ' + Members.Lastname + ' ' + Members.Suffix)), '  ', ' ') As varchar(100))
            End,
      Addresses.AddressType, Addresses.ShipTo, Addresses.Street1, Addresses.Street2, Addresses.City,
      Addresses.Abrv, Addresses.State, Addresses.Zipcode, Addresses.Country,
      Addresses.PostalZone, Addresses.Mailings, Addresses.Packages, Addresses.Commissions,
      Addresses.Important, Addresses.StartDate, Addresses.EndDate
From
      ptblAddresses As Addresses left outer join
            ptblMembers As Members on Addresses.IDNumber = Members.IDNumber left outer join
            ptblCampgrounds As Campgrounds on Addresses.IDNumber = Campgrounds.IDNumber left outer join
            ptblOffices As MOffice On Members.Office = MOffice.OfficeID and MOffice.OfficeID = '1' left outer join
            ptblOffices As COffice On COffice.OfficeID = '1'
Where (MOffice.OfficeID = '1' or COffice.OfficeID = '1') And Addresses.EndDate > GetDate()
--End View
The way i'm storing addresses is every address that has been mailed to has been saved and cannot be deleted (to look up where packages, etc... went and not having the "New" address replace the one in which it was actually sent.)  When a change is made to the address the enddate gets set to GetDate() thereby making it no longer effective.  A person can have 2 address types.  Temporary and Permanent (self explanitory).  A temporary address takes precedence over the permanent address if GetDate is between Addresses.StartDate and Addresses.EndDate else should display the Permanent address.
The problem lies in that it is returning 2 results for members with an active temporary address.  (Both Home and Temporary).  Now the EndDate on the permanent address is always 12/31/2050 while active so I could get the result by using Top 1 and order by Addresses.EndDate (SHOULD return the temporary address).  However whenever I specify the Top clause nothing is being returned at all (and the query takes 10 seconds in leiu of .3 seconds with above query).
Generally this view is called specifying IDNumber(s) (using in clause) and by various bitfields (mailing, packages, important, commissions) being set to true.
This is used for batches of members and/or campgrounds (why stored procedure won't work correctly) in which I need 1 address per distinct idnumber.  Any ideas?  I would greatly appreciate it...
-ketapillar
Question by:ketapillar
3 Comments
LVL 70
Accepted Solution
by:
Scott Pletcher earned 2000 total points
I think you could expand your WHERE clause to check the addressType and only select a 'Permanent' address if a 'Temporary' address didn't exist, like so:
And (Addresses.AddressType = 'Temporary' OR NOT EXISTS(
      SELECT 1
      FROM Addresses A2
      WHERE A2.IDNumber = Addresses.IDNumber
      AND A2.AddressType = 'Temporary'
      AND A2.EndDate > GETDATE()))
LVL 15
Expert Comment
by:Ralf Klatt
Which address is the primary address? "Temp" or "Home"?
If it is "Temp" I would state like:
create/alter procedure yourProcedure
     @yourCondition int (or whatever)
as
declare @chkTemp int
select @chkTemp = count(yourValue) from yourTable where yourData = @yourCondition
if @chkTemp = 0
     begin
          ... (yourScriptA)
     end
if @chkTemp > 0
     begin
          ... (yourScriptB)
     end
If "Home" is the important condition you'll just have to change "chkTemp" to "chkHome" in the above sequence.
Best regards, Raisor
LVL 3
Author Comment
by:ketapillar
Thanks ScottPletcher it seems to be working fine now.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
Recently we ran in to an issue while running some SQL jobs where we were trying to process the cubes.  We got an error saying failure stating 'NT SERVICE\SQLSERVERAGENT does not have access to Analysis Services. So this is a way to automate that wit…
It is possible to export the data of a SQL Table in SSMS and generate INSERT statements. It's neatly tucked away in the generate scripts option of a database.
This videos aims to give the viewer a basic demonstration of how a user can query current session information by using the SYS_CONTEXT function
Viewers will learn how to use the SELECT statement in SQL and will be exposed to the many uses the SELECT statement has.
607 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
