SQl - Calculate difference between rows for same column - reset calculation for next id
Hi all,
I'm new to your site so please forgive any faux pas.  I have an SQL table where I need to calculate the difference in survey scores from between rows for the same column.  I'm new to SQL.  The following are examples of how the data looks in the table.
USERID     Surveydate        SurveyScore
123      01/13/02           6.75
123      02/16/03              5.10
234      05/14/02              2.75
234      06/12/03              3.00
234      07/01/02              2.88
345      02/14/02           1.82
456      01/01/03
456      02/15/03              4.35
456      03/21/03              3.25
Please let me know if you need more information.
Thanks in advance.
jfreelandAsked:
_ys_Commented:
Need a little more info.
Difference in survey scores with regards to what  ... date ?
jfreelandAuthor Commented:
We need to subtract the next survey score from the previous date's score:
234     05/14/02             2.75 (no previous date so = 0)
234     07/01/02             2.88 (2.88 - 2.75 = .13)
234     06/12/03             3.00 (3.00 - 2.88 = .12)
123     01/13/02           6.75
123     02/16/03             5.10
Sorry - sent it before I was done.
123     01/13/02             6.75 (no previos date so = 0)
123     02/16/03             5.10 (5.10 - 6.75 = -1.65)
Hope this helps.
Thanks again.
Cloud Class® Course: Microsoft Windows 7 Basic
This introductory course to Windows 7 environment will teach you about working with the Windows operating system. You will learn about basic functions including start menu; the desktop; managing files, folders, and libraries.
_ys_Commented:
Thanks. That's what I needed to know.
Let me put my SQL hat on ... back soon.
_ys_Commented:
Personally I use SQL server 2000, so this may have to be tailored to fit your actual scripting needs.
-- Create my own representation of your table
DECLARE      @tblSurveyScore TABLE
      USERID smallint NOT NULL,
      SurveyDate smalldatetime NOT NULL,
      SurveyScore dec(3,2) NOT NULL
INSERT
INTO      @tblSurveyScore
VALUES      (123, '01/13/02', 6.75)
INSERT
VALUES      (123, '02/16/03', 5.10)
INSERT
VALUES      (234, '05/14/02', 2.75)
INSERT
VALUES      (234, '06/12/03', 3.00)
INSERT
VALUES      (234, '07/01/02', 2.88)
INSERT
VALUES      (345, '02/14/02', 1.82)
-- actual work starts here
DECLARE      @tmpTblSurveyScore TABLE
INSERT
INTO      @tmpTblSurveyScore
SELECT      USERID, SurveyDate, SurveyScore
FROM      @tblSurveyScore
ORDER BY USERID, SurveyDate ASC
DECLARE      @tmpTblSurveyScoreDiff TABLE
      Diff dec(3,2) NOT NULL
SELECT      *
FROM      @tmpTblSurveyScore
DECLARE       @nUserId smallint
      ,@dtSurveyDate smalldatetime
      ,@fSurveyScore dec(3,2)
      ,@fSurveyScoreDiff dec(3,2)
SELECT      TOP 1
       @nUserId = USERID
      ,@dtSurveyDate = SurveyDate
      ,@fSurveyScore = SurveyScore
WHILE (0 <> @@ROWCOUNT)
BEGIN
      SELECT TOP 1
            @fSurveyScoreDiff = SurveyScore - @fSurveyScore
      WHERE      USERID = @nUserId
      AND      SurveyDate <> @dtSurveyDate
      IF 0 = @@ROWCOUNT
      BEGIN
            PRINT 'No previous to diff'
            SET @fSurveyScoreDiff = 0
      END
      INSERT
      INTO      @tmpTblSurveyScoreDiff
      VALUES      (@nUserId, @dtSurveyDate, @fSurveyScoreDiff)
      DELETE
      AND      SurveyDate = @dtSurveyDate
      SELECT      TOP 1
             @nUserId = USERID
END
-- final result
SELECT      *
FROM      @tmpTblSurveyScoreDiff
_ys_Commented:
U using SQL server 2000?
If not I could munge this for another db.
Yes, indeed, we are using SQL server 2000 but, alas, I am a newbie.  Thanks for the code you posted - I'm about to test it now.  Will let you know results as soon as I can - it certainly looks very promising.
Hello again,
Your code looks great, but I still have two problems. (I apologize if my initial question was garbled.  I've been struggling with this for three days and I'm a bit numb.)  Hopefully these aren't insurmountable problems.
1. I need to save the results as a view to use in a Crystal Report.  Query Analyzer let me run the code, but I can't seem to save it as a view either there or in Enterprise Manager.  Can you point me in the right direction?
2. Is it possible to have the "0" values show in the first row and the calculations in the subsequent rows?  Sorry to be a pain, but I suspect it will be cleaner to fix it here rather than in Crystal.  Example data below:
Userid       SurveyDate                  SurveyScore   Diff
123         2002-03-13 00:00:00        3.63               -.38 (0)
123          2003-03-19 00:00:00        3.25               .00  (-.38)
234          2002-06-20 00:00:00        4.25               .25  (0)
234          2002-12-31 00:00:00        4.50               .25  (.25)
234          2003-03-26 00:00:00        4.75               .00  (.25)
Again, thanks for all your help - it's greatly appreciated.
_ys_Commented:
Q1.
Create this code snippet as a stored procedure instead of a straight script. The results from a stored procedure are bindable within crystal reports - you don't need to use an intermediatory storage.
Q2.
Sure. Np. Always do as much as possible within SQL before passing over to Crystal - it's generally more efficient.
Complete snippet below - this will create a stored procedure as well.
CREATE PROCEDURE [dbo].[surveryScoreDifferences]
AS
BEGIN
      -- reorder the existing table, for use within the WHILE loop
      INSERT
      FROM      @tblSurveyScore -- [this is the name of your existing table/view]
      -- this is to be our result set [it's column sizes should match the original table]
            SurveyScore dec(3,2) NOT NULL,
            ,@fSurveyScoreDiff dec(3,2) -- [again, these should match the original table]
      -- select the first row to be processed
      SELECT      TOP 1
             @nUserId = USERID
      -- while we still have rows to process
      WHILE (0 < @@ROWCOUNT)
      BEGIN
            SELECT TOP 1
            -- if no previous score, difference should be 0
            IF 0 = @@ROWCOUNT
            BEGIN
                  PRINT 'No previous to diff' -- [debug purposes only]
            END
            -- we have a row for our result set
            INSERT
            VALUES      (@nUserId, @dtSurveyDate, @fSurveyScore, @fSurveyScoreDiff)
            -- row has been processed, delete it ...
            DELETE
            -- ... and get the next
            SELECT      TOP 1
                   @nUserId = USERID
      END
      -- return the results
      SELECT      *
END
malharoneCommented:
why dont you just create the dataset yourself and set the dataset manually?
use the following link... it explains how to "push" data to your report instead of the "report" pulling data from the database. The "push" method may be complicated, but offers great flexibility and functionality -- which may NOT be built in as a SQL function.
http://www.freevbcode.com/source/WalkthroughCrystalReport.zip
Programming Languages-Other
