Help with Code to work! ASP , SQL
I'm still new to all of this! But hopefully someone can help out
I'm trying to get this AND statement to work.
It's getting the variablies across, but I can't see
what I'm doing wrong. Can't get the Redirect to work.
Companyidnumber =  TRIM(rs1("company_id"))
   Cergo = TRIM(rs1("ergo"))
   response.write(Cergo)
   response.write(Companyidnumber)
    IF NOT rs1.EOF = true & Cergo = False then
      'record was returned, good login!'
         Session("UID") = userid
         Response.Redirect ("entryform.asp")
       Response.End
   End IF
   else
     response.write("I'm here in this branch")
  end if
Any help will be grateful
d.
DstathakisAsked:
mlmccConnect With a Mentor Commented:
there are four possible combinatiions to test
 If (Not rs1.EOF) And (Not Cergo) then
 else If (Not rs1.EOF) And (Cergo) then
 else If (rs1.EOF) And (Not Cergo) then
 else if (rs1.EOF) And (Cergo) then
 else ERROR
Think through what each combination means then determine where the user should go.
mlmcc
mlmccCommented:
Should the & be && asit is in C or C++?
mlmcc
mlmccCommented:
Since you are already comparing booleans
rs1.EOF = TRUE is true when rs1.eof is true
Try this
If (Not rs1.EOF) && (Not Cergo) then
mlmcc
Free Tool: SSL Checker
Scans your site and returns information about your SSL implementation and certificate. Helpful for debugging and validating your SSL configuration.
DstathakisAuthor Commented:
Thank you it  help me out. Next how would I say the oppose.
             Response.End
      'I need need it not to be right so the user will be redirect somewhere else?
              Response.Redirect ("queryform.asp")
             Response.End
   else
   end if
   end if
 end if
d.
mlmccCommented:
Try this
        If (rs1.EOF) OR (Cergo) then
mlmcc
I missed comunicated what I was needing! I need to have the first part of this
statement true but the second part false.
I tried changing it around but I missed!
If (Not rs1.EOF) or (Cergo) then
d.
mlmccCommented:
I don't follow.  What are you trying to test for?
What does rs1.EOF indicate when it is TRUE?
What does Cergo indicate when it is TRUE?
mlmcc
I'm doing a secruity check if the user password and id pan out then rs1.EOF comes back true I'm also checking another field and depending on who the user is, will return true or false. This in return will direct them to the right ASP page I set-up.
Hope this makes sense.
thanks you've been alot of help!
I'm running into one final error!
Can you help!
Here's what I getting as an Error Message:
Error Type:
ADODB.Field (0x800A0BCD)
Either BOF or EOF is True, or the current record has been deleted. Requested operation requires a current record.
Below is the code I'm running it's bombing on the last else statment. It states the error is
happening on line 35 which is Cergo = rs1("ergo")
Hope I make sense
d.
 IF LEN(userid) <> 0 AND LEN(pwd) <> 0 Then
   strSQL=  "SELECT * "                              &_
            "  FROM users "                        &_
          " WHERE uid = '" & userid & "'"         &_
          "   AND password = '" & pwd & "'"
   SET rs1 = Objconn.execute(strSQL)
    Cergo = rs1("ergo")
      '*****This statement will only pass if the users password and ID are correct'
      '*****Back True and the user is NOT an Employee of Ergo '
              Companyidnumber = rs1("company_id")
           Response.End
  '*****This statment will only work if Ergo Employee'
  '*****Has entered the statement and correct Password and ID'
         Companyidnumber =  " "
         Response.End
   '*****This statment WILL NOT pass anyone'
   '****Because password and ID are incorrect'
   Else
    response.write("I'm here")
    End IF
    End IF
    End IF
mlmccCommented:
The recordset didn't open correctly.
How is it declared?
mlmcc
Sorry, I was finally able to figure it out.
mlmccCommented:
Glad I could help
mlmcc
