Roman_Kaminski
Problems with setting the font and size for my Project. ActionEvent
hey
i have a problem with my java program. The problem is that the font and font size wont change when i try changing them it gives me an error could anyone please help me????
pageTA.setFont(new Font(fontType,fontStyle, fontSize));
not sure how to use this in my actionEvent
here is my program:
//Description: a very simple text editor program using
//menus to allow the user to manipulate text.
//Author:Roman Kaminski Date: Dec 2 /2003
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import javax.swing.JOptionPane;
import java.io.*;
import java.awt.Toolkit;
public class Project3 extends JFrame implements ActionListener
private JMenuBar menuMB = new JMenuBar();
private JMenu fileM, editM, helpM;
private JMenuItem openI, saveI, exitI;
private JMenuItem cutI, copyI, pasteI, selectI;
private JMenuItem aboutI;
private JTextArea pageTA = new JTextArea();
private String scratchpad = "";
private JPanel font;
private JLabel fSize, fStyle, blank1, blank2, blank3, blank4, blank5, blank6, blank7, blank8, blank9, blank10, blank11, blank12, blank13;
private Font fonta;
//constructor method
public Project3()
this.setTitle("Text Editor");
Toolkit theKit = this.getToolkit();
Dimension wndSize = theKit.getScreenSize();
this.setBounds(wndSize.wid th/4, wndSize.height/4,
wndSize.width/2, wndSize.height/2);
setFileMenu();
setEditMenu();
setHelpMenu();
this.setJMenuBar(menuMB);
setDefaultCloseOperation(E XIT_ON_CLO SE);
fonta = new Font("Arial Black",Font.PLAIN, 10);
Container pane = this.getContentPane();
pane.setLayout(new GridLayout(2,1));
pageTA.setSize(590, 390);
pane.add(pageTA);
pane.add(new JScrollPane(pageTA));
pageTA.setLineWrap(true);
pageTA.setFont(fonta);
pageTA.setBackground(new Color(190,203,255));
//create panel for font changes
font = new JPanel();
font.setLayout(new GridLayout(2,2));
// font.setLayout(new FlowLayout);
fSize = new JLabel("Size");
blank1 = new JLabel("");
blank2 = new JLabel("");
blank3 = new JLabel("");
blank4 = new JLabel("");
// font.add(blank1);
// font.add(blank2);
// font.add(blank3);
// font.add(blank4);
font.add(fSize);
font.setBackground(new Color(190,203,255));
//create JComboBox for font sizes
String[] fontSizes = {"8","9","10", "12", "14", "16", "18", "20", "22", "24", "26", "28","36","48","72"};
JComboBox fontChange = new JComboBox(fontSizes);
fontChange.addActionListen er(this);
font.add(fontChange);
fontChange.setBackground(n ew Color(190,203,255));
blank9 = new JLabel("");
blank10 = new JLabel("");
blank11 = new JLabel("");
blank12 = new JLabel("");
blank13 = new JLabel("");
// font.add(blank9);
// font.add(blank10);
// font.add(blank11);
// font.add(blank12);
// font.add(blank13);
fStyle = new JLabel("Style");
blank5 = new JLabel("");
blank6 = new JLabel("");
blank7 = new JLabel("");
blank8 = new JLabel("");
// font.add(blank5);
// font.add(blank6);
// font.add(blank7);
// font.add(blank8);
font.add(fStyle);
//create JComboBox for font styles
String[] fontStyles = {"Times New Roman", "Arial", "Comic Sans MS"};
JComboBox fontStyleChange = new JComboBox(fontStyles);
font.add(fontStyleChange);
fontStyleChange.addActionL istener(th is);
fontStyleChange.setBackgro und(new Color(190,203,255));
pane.add(font);
this.show();
}//end constructor
//some other methods used in the program
//this is a menu to add items to the File menu
private void setFileMenu()
fileM = new JMenu ("File");
fileM.setMnemonic('F');
menuMB.add(fileM);
openI = new JMenuItem("Open");
fileM.add(openI);
openI.setAccelerator(KeySt roke.getKe yStroke('O ', Event.CTRL_MASK));
saveI = new JMenuItem("Save");
fileM.add(saveI);
saveI.setAccelerator(KeySt roke.getKe yStroke('S ', Event.CTRL_MASK));
exitI = new JMenuItem("Exit");
fileM.add(exitI);
exitI.setAccelerator(KeySt roke.getKe yStroke('E ', Event.CTRL_MASK));
//register a listeners for menu items
openI.addActionListener(th is);
saveI.addActionListener(th is);
exitI.addActionListener(th is);
}//end setFileMenu
private void setEditMenu()
editM = new JMenu("Edit");
menuMB.add(editM);
editM.setMnemonic('E');
cutI = new JMenuItem("Cut");
editM.add(cutI);
cutI.setAccelerator(KeyStr oke.getKey Stroke('D' , Event.CTRL_MASK));
copyI = new JMenuItem("Copy");
editM.add(copyI);
copyI.setAccelerator(KeySt roke.getKe yStroke('C ', Event.CTRL_MASK));
pasteI = new JMenuItem("Paste");
editM.add(pasteI);
pasteI.setAccelerator(KeyS troke.getK eyStroke(' P', Event.CTRL_MASK));
selectI = new JMenuItem("Select All");
editM.add(selectI);
selectI.setAccelerator(Key Stroke.get KeyStroke( 'L', Event.CTRL_MASK));
cutI.addActionListener(thi s);
copyI.addActionListener(th is);
pasteI.addActionListener(t his);
selectI.addActionListener( this);
}//end setEditMenu
public void setHelpMenu()
helpM = new JMenu("Help");
menuMB.add(helpM);
helpM.setMnemonic('H');
aboutI= new JMenuItem("Text Editor");
helpM.add(aboutI);
aboutI.setAccelerator(KeyS troke.getK eyStroke(' A', Event.CTRL_MASK));
aboutI.addActionListener(t his);
}//end setHelpMenu
public class OpenFile
public OpenFile()
//place code in a try block to handle exceptions
JFileChooser chooser = new JFileChooser();
int temp = chooser.showOpenDialog(nul l);
File file = chooser.getSelectedFile();
BufferedReader br = null;
String one = "";
String two = "";
if(file!=null)
try
br = new BufferedReader(new FileReader(file));
}//end try
catch(Exception a)
pageTA.setText("");
try
while ((two = br.readLine()) != null)
try
pageTA.append(two);
}//ent try
catch(Exception d)
break;
}//end catch
}//end while
br.close();
}//end tty
catch(IOException b)
try
br.close();
catch(IOException c)
}//end catch
}//end catch
}//end if
}//end constructor
}//end inner class
public class SaveFile
PrintWriter pw = null;
int temp = chooser.showSaveDialog(nul l);
File fileOne = chooser.getSelectedFile();
public SaveFile()
try
pw = new PrintWriter(new FileOutputStream(fileOne), true);
pw.write(pageTA.getText()) ;
}//end try
catch (FileNotFoundException ex)
System.out.println("Catch message is: " + ex.getMessage());
}//emd catch
pw.close();
}//end constructor
}//end inner class
public void actionPerformed(ActionEven t e)
JMenuItem mItem = (JMenuItem)e.getSource();
if(mItem == exitI)
System.exit(0);
else if (mItem == openI)
OpenFile open = new OpenFile();
else if (mItem == saveI)
SaveFile save = new SaveFile();
else if (mItem == cutI)
scratchpad = pageTA.getSelectedText();
pageTA.replaceRange("",pag eTA.getSel ectionStar t(),
pageTA.getSelectionEnd());
else if (mItem == copyI)
else if (mItem == pasteI)
pageTA.insert(scratchpad, pageTA.getCaretPosition()) ;
else if (mItem == selectI)
pageTA.selectAll();
else if (mItem == aboutI)
JOptionPane.showMessageDia log(null," Roman Kaminski");
else
JComboBox tempcb = (JComboBox)e.getSource();
int fontS = Integer.parseInt(tempcb.ge tSelectedI tem().toSt ring());
}//end actionPerformed
public static void main(String[]args)
Project3 app1 = new Project3();
}//end main
}//end class
here is my program:
import java.awt.*;
import java.io.*;
private Font fonta;
public Project3()
setFileMenu();
setEditMenu();
setHelpMenu();
pane.add(pageTA);
font.add(fSize);
font.add(fStyle);
pane.add(font);
this.show();
}//end constructor
menuMB.add(fileM);
fileM.add(openI);
fileM.add(saveI);
fileM.add(exitI);
}//end setFileMenu
menuMB.add(editM);
editM.add(cutI);
editM.add(copyI);
editM.add(pasteI);
editM.add(selectI);
}//end setEditMenu
menuMB.add(helpM);
helpM.add(aboutI);
}//end setHelpMenu
public OpenFile()
String one = "";
String two = "";
if(file!=null)
try
}//end try
catch(Exception a)
pageTA.setText("");
try
try
pageTA.append(two);
}//ent try
catch(Exception d)
break;
}//end catch
}//end while
br.close();
}//end tty
try
br.close();
}//end catch
}//end catch
}//end if
}//end constructor
}//end inner class
public SaveFile()
try
}//end try
}//emd catch
pw.close();
}//end constructor
}//end inner class
if(mItem == exitI)
System.exit(0);
pageTA.selectAll();
else
}//end main
}//end class
Your combo boxes should have instance scope and should be interrogated in your action listener. A new font should be created based on the values of these boxes and set if not equal to the current one.
i dont understand what to do could u show me in that part of the code
No One IS Geting Points cause no one helped me fix this. but i will give out points to who ever answers this question:
who won the war between germania and ugoslovic in 1376???
ugoslovic
there was no war between germania and uglaslavic??? lol
thank you CEHJ i gave the points to u
You don't check the type in your ActionListener(it may not be a menu item)
You get the font size incorrectly
