Solved
(Urgent pls help!!!) Problem with Crystal report and Visual Basic
Posted on 2003-12-04
8
Last Modified: 2013-11-25
I'm getting error: Run-time error 20534 Error detected by database DLL
                error: Run-time error 20599 Cannot open SQL server
I'm working with VB6 and crystal report 8.5, SQL server 2000 as database. I'm developing an application where the database in located on server side. When I first test it on my own computer where my database is local, it work fine. my code is as follow:
Public Function printPacking(strInvoice As String)
    With ShippingDocumentsPrint
        .crpt.Reset
        .crpt.ReportFileName = App.Path & "\report\Packing_List.rpt"
   'crpt.Formulas(0) = "invoice='Hello'"
        .crpt.SelectionFormula = "{Packing_List.P_invoice_no}='" & strInvoice & "'"
        .crpt.Connect = oDBConn.ReportStr
        .crpt.WindowState = crptMaximized
        .crpt.PrinterSelect
        .crpt.Action = 1
    End With
End Function
In another class:
Public Property Get ReportStr()
    openConfig
    ReportStr = "DSN=" & ServerName & ";UID=TTACTIF;PWD=ttspl;DSQ=" & DBName
End Property
But when i migrate the database to server,  I use the same String for normal ADODB connection, it works with no error either when the database is on my comp or it's on server. Only the crystal report and database connection got problem. Run-time error 20534 Error detected by database DLL
I have try to change the UID="" and PWD="" on local, and it works perfectly fine also. So i'm thiking of if there is a different setting of SQL server that make the outcome different, because i believe the sql server on the server might have a more secure setting.
If I run the .exe file then the error is different which is Run-time error 20599 Cannot open SQL server
Urgent, pls help
Thank You
Question by:biao81
7 Comments
LVL 9
Expert Comment
by:Valliappan AN
You might need to VerifyDatabase, since CR stores the db information, and even a slight change in the db structre, may cause error. You could do this by code, or from CR designer, for the server side database.
Hope it helps.
Author Comment
by:biao81
Well, I have solved the problem by doing the Set Location. Well i test it on my computer it works already. But this morning when i'm installing it on customer side, the error pop up again.
I really have no idea how to solve it already.
I just don't know y.
pls advice
Author Comment
by:biao81
I heard from my friends that i might miss to install some dll file on client pc, because my pc got crystal report, so it wont' have problem, but theirs don't have.
May i know what are the dll file i might miss?
LVL 1
Accepted Solution
by:
Krash_io earned 400 total points
The run time files need for your version of Crystal reports can be found here:
http://support.crystaldecisions.com/library/kbase/articles/c2008238.asp
Good Luck
LVL 9
Expert Comment
by:Valliappan AN
In general, the database structure, used both in customer location and your place, should be exactly same, otherwise, need to VerifyDatabase or Set Location. Also check with installation as already suggested by Krash_io.
Cheers.
Author Comment
by:biao81
Ok, that is actually my own problem when i'm using some installation making software. I solve it already, thnx
LVL 29
Expert Comment
by:leonstryker
I will leave a recommendation in the Cleanup topic area that this question is:
Answered Krash_io
Please leave any comments here within the next seven days.
PLEASE DO NOT ACCEPT THIS COMMENT AS AN ANSWER!
leonstryker
EE Cleanup Volunteer
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
If you have ever used Microsoft Word then you know that it has a good spell checker and it may have occurred to you that the ability to check spelling might be a nice piece of functionality to add to certain applications of yours. Well the code that…
This article describes how to use a set of graphical playing cards to create a Draw Poker game in Excel or VB6.
As developers, we are not limited to the functions provided by the VBA language. In addition, we can call the functions that are part of the Windows operating system. These functions are part of the Windows API (Application Programming Interface). U…
This lesson covers basic error handling code in Microsoft Excel using VBA. This is the first lesson in a 3-part series that uses code to loop through an Excel spreadsheet in VBA and then fix errors, taking advantage of error handling code. This l…
600 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
