problem with setting up a Web Ceonferance between to pc's on the same lan
I hope someone can help me, I haev running a Mix Domain NT4 / 2000 domain
I am trying to get a web conferance going between to pc's on the same lan
Each Pc is Win 98se I have tested the software on each Pc, which allow me to view the image from the webcam on my screen, but when I try to dail up the other PC to revice the image, then I am only getting a blank screen. but I am able to use the whiteboard / chat and trafers options between them.
chriskchambersAsked:
MikeKaneCommented:
In TOOLS - OPTIONS - VIDEO  Make sure you have the automatically send and receive video at the start of each call turned on.
chriskchambersAuthor Commented:
Thanks for your reply, but it turn out not to be this, it was a problem with a bit of software my boss instored on the network, whcih monitors and limits protocols, and once I removed this from the domain, the web Cam software and proctols worked.
Windows OS
