Solved
Wireless Router and Satellite connection ... wireless connection not working
Posted on 2004-03-21
5
Last Modified: 2013-11-29
I am having a problem getting this setup to work in full. We are working with a desktop wired to the router and a laptop both wired and wireless to the router. The router is Netgear WRG614, the Toshiba laptop is using Intel Pro Wireless (integrated). We have gotten the wired solutions to work (intermittently), but the wireless solution has not become clear. I know what I am doing for the most part and I feel I am missing something simple. I have run this setup with DHCP and just tried without. I also just input the MAC address for the laptop in the router setup utility, but to no alas.
I need a full explanation of how to make this work to make sure I am not missing anything. Points galore here. The satellite connection is  Directway dw6000 modem (two way connection). There is something shady about the satellite stuff, but I have tried to focus on the base networking stuff, as the connection has proved to work at times (albeit slow).
Please let me know what else you need to know.
Thank you so much for your time!!!
Scott
Question by:PcVerse
  • 3
  • 2
5 Comments
LVL 11
Expert Comment
by:YohanShminge
What operating system is running on the wireless laptop?  What EXACTLY is your problem with your wireless system?  If you're having connectivity issues, try other channels or move closer to the wireless router.  If you're using MAC filtering, make sure you've typed your MAC address exactly.  There are lots of other possible problems, but it would help to get more information...
Author Comment
by:PcVerse
Sorry about leaving the obvious out. I am so frustrated with this right now and have gone through so many variations I don't know where to begin. Okay, Win XP on the desktop and the laptop. We have gotten it to the point where both would connect with wired connections, but the wireless is still not going. In playing with different configurations, the notification keeps saying 'click here to see available wireless networks' and I do so and click connect (it registers the Netgear wireless router) and okay ... and nothing. It still doesn't create a workable connection. The network icon for the wireless connection that sits on the toolbar says 'wireless network not available'. The hardware connection that allows the wired lans to work is: satellite modem to one of the main ports of the netgear wireless router (not the uplink port or whatever that is) and the two lan connections out from there as well. I have to connect the modem to the uplink port in order to get to the wireless config screen, I thought I had changed its ip, but somehow it defaulted.
I hope this helps the helping.
Thank you again for your time. (I will be adding points on top of the 500 for this).
Author Comment
by:PcVerse
(XP Pro)
LVL 11
Accepted Solution
by:
YohanShminge earned 1500 total points
OK, so you're letting Windows configure your wireless card for you?  Have you tried to manually configure the settings?
You mean the modem must be connected to the router in order for the screen to appear?  This should not be necessary.  Is your router not acting as a DHCP server?
Do you mean the router's IP, or your laptops?
Author Comment
by:PcVerse
Thank you very much for your attention. I stumbled across the answer ... I released and renewed the ip addresses and that seemed to clear whatever conflict was going on (as well as resetting the router). I am awarding the points anyway ... because I can!! Thanks so much
Improve Your Query Performance Tuning
In this FREE six-day email course, you'll learn from Janis Griffin, Database Performance Evangelist. She'll teach 12 steps that you can use to optimize your queries as much as possible and see measurable results in your work. Get started today!
Join & Write a Comment
This article will show you step-by-step instructions to build your own NTP CentOS server.  The network diagram shows the best practice to setup the NTP server farm for redundancy.  This article also serves as your NTP server documentation.
In this article, the configuration steps in Zabbix to monitor devices via SNMP will be discussed with some real examples on Cisco Router/Switch, Catalyst Switch, NAS Synology device.
This video gives you a great overview about bandwidth monitoring with SNMP and WMI with our network monitoring solution PRTG Network Monitor (https://www.paessler.com/prtg). If you're looking for how to monitor bandwidth using netflow or packet s…
Monitoring a network: how to monitor network services and why? Michael Kulchisky, MCSE, MCSA, MCP, VTSP, VSP, CCSP outlines the philosophy behind service monitoring and why a handshake validation is critical in network monitoring. Software utilized …
595 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
