Hi
I have setup a wireless 54G lan in my house with the linksys router, DSL modem and pc(win2K) upstairs. I have a Win2k laptop with wireless 54G pcmcia card in it and downstairs another Win2K PC. Up to now all was working perfectly well....... Until I rebuilt the machine downstairs with WIN XP. I am no expert on WIN XP but it seems to have detected my wireless lan card and configured it - the status says its enabled and signal strength is excellent.
However I cannot connect to the Internet or to any other PC in the house.
Ipconfig /all on the winXP machine reveals the following
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : precedent2
Primary DNS Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 13:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Wireless-G PCI Adapter
Physical Address. . . . . . . . . : 00-0C-41-14-CC-3E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . . . . . . . . . . : 192.168.1.103
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
ipconfig /all on the laptop that can connect to the internet reveals the following
Host Name . . . . . . . . . . . . : IEM00051
Node Type . . . . . . . . . . . . : Broadcast
Description . . . . . . . . . . . : Wireless-G Notebook Adapter
Physical Address. . . . . . . . . : 00-0C-41-2E-5F-8C
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 194.168.4.100
194.168.8.100
Lease Obtained. . . . . . . . . . : 23 March 2004 20:00:18
Lease Expires . . . . . . . . . . : 24 March 2004 12:40:18
I believed the WinXp setup should have picked up the router and obtained an IP address from it but that does not appear to be the case. I even tried uninstalling the card and starting from scratch. The funny thing is when I "View Available Wireless Networks" it picks up linksys1 which is my router
How can I get this machine to see the outside world ? What am I not doing ????
Also post the ssid for the lan, and is WEP turned on?
