Solved
PC will not boot, get power signal but will not start
Posted on 2004-04-05
9
Last Modified: 2010-04-25
i needed to remove my secondary HDD because it was faulty.  Did that, but after re-booting the pc would not recognize the primary master (even though i never changed the cabling or the jumper settings).  it would not recognize it in the bios either.  So, i reseated everything but while doing that i accidently pulled out and stripped the IDE(?) cable for the USB 2.0 ports on the front of the case.  Are these replacement cables widely available?  I don't know if this is specifically causing the problem but now when i press the power button on the front of the case it doesn't even attempt to start, no fan, no beeps, nothing.  it just sits there.  i know its getting power because the power LED light on the MOBO is lit.  And the wattage is correct.  Any help?
Question by:soundifound
7 Comments
LVL 69
Expert Comment
by:Callandor
Remove the stripped cable completely to see if the system will boot.  As for your hard drives, if the master is a Western Digital, it will require the jumper to be on single, versus master with a slave.
Author Comment
by:soundifound
Still nothing.  I changed the HDD but can't test to see if it worked since the system doesn't boot.
LVL 1
Expert Comment
by:HeathAdams
The power supply fan doesn't even come on?  Waht do you mean stripped?
We value your feedback.
Author Comment
by:soundifound
the prongs on the end of the USB connection cable came loose from the IDE cable that connects to the MOBO.
Author Comment
by:soundifound
alright i can get it to boot.  the cable that i was talking about (what is this called as i need a replacement) that connects the power button to the MOBO was stripped/loose.
LVL 69
Expert Comment
by:Callandor
It's a USB header bracket cable: http://www.tadara.com/items-id=8202.htm
LVL 1
Accepted Solution
by:
Computer101 earned 0 total points
PAQed, with points refunded (250)
Computer101
E-E Admin
How can this article save you time AND money?  In just a few minutes you may discover something you didn't know existed that is easy enough for you to fix yourself!
Skype is a P2P (Peer to Peer) instant messaging and VOIP (Voice over IP) service – as well as a whole lot more.
Finding and deleting duplicate (picture) files can be a time consuming task. My wife and I, our three kids and their families all share one dilemma: Managing our pictures. Between desktops, laptops, phones, tablets, and cameras; over the last decade…
Want to learn how to record your desktop screen without having to use an outside camera. Click on this video and learn how to use the cool google extension called "Screencastify"! Step 1: Open a new google tab Step 2: Go to the left hand upper corn…
Suggested Courses
Course of the Month13 days, 9 hours left to enroll
581 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
