Check out our new AWS podcast with Certified Expert, Phil Phillips! Listen to "How to Execute a Seamless AWS Migration" on EE or on your favorite podcast platform. Listen Now
Best signal/range wireless router for home wireless LAN
DMVance
DMVance asked
on
Last Modified: 2013-12-09
I'm looking for a wireless router with good signal strength/range. I was unable to get the Linksys WRT54G to go over forty feet until I added a booster antenna. No line of sight between the wireless router and the one wireless computer on the same floor - two drywall walls with fiberglass, and metal AC ductwork in the ceilings of the hallway between the rooms.
What makes and models have better signal strength/range?
Thank you,
Daniel
Watch Question
Networking Engineer
Unlock this solution with a free trial preview.
(No credit card required)
Get Preview
KronosTM,
Excellent links and information. I did not see mention of brand name thus am I correct to assume that signal strength and range does not vary between manufactures of wireless APs?
Is there a AP vendor comparsion chart available?
Daniel
Adrian DobrotaNetworking Engineer
<< am I correct to assume that signal strength and range does not vary between manufactures of wireless APs? >> Yes, you are correct.
They vary but not much. Only the "outdoor" APs have higher output power.
If there's a chart then I'm unaware of it. It's pretty hard though, since thtis is quite new terrain. Anyway, most RF modules and processors are the same, and that's what's important. Just to make a shot in the dark, I'd say there aren't currently more than 20-30. The differences are mostly in software , cases and minor electronic things.
KronosTM,
You have been very helpful.
I'm awarding the points to you.
BTW, I did find a couple of comparison charts.
http://compnetworking.about.com/cs/wirelessrouters/tp/80211ghome.htm
http://www.tomsnetworking.com/ProductGuides-Wireless.php
Thank you,
Daniel
second link seems pretty good. I'll bookmark it.
You've been very helpful too  :)
KronosTM
Please provide your email to receive a free trial preview!
OR
Please enter a first name
Please enter a last name
