Using Function Keys for user interaction in Flash movies causing problems with I.E. functionality - Help!!
chelseajake
chelseajake asked
on
Last Modified: 2008-03-10
I need to make it so that my user presses the F10 function key to move to the next frame in my movie.
I used the following code:
onClipEvent (enterFrame){
if (Key.isDown(121)){
_level8.gotoAndPlay(121);
When I play the movie, the function key does seem to work; HOWEVER, strange things are also happening. When I press F10, the F in the File Menu on Internet Explorer is highlighted/selected first, then it will go to the next frame as I want. When I get to the next frame, I want the user to type a word that begins with an E. However, when I do that, the E in the Edit menu on Internet Explorer is already highlighted because the File Menu was inadvertently selected in the previous frame. Thus, there is a stalling.
This doesn't happen with any other type of interaction, just a function key key press interaction. This is a huge problem for me as to truly simulate my product, I MUST have the user be able to press F10. HOwever, I don't want all that strange stuff that is happening with the File and Edit menus on I.E to happen either. I am distributed this to hundreds of users over the web thus, I can't control their i.e. settings nor do I want to tell them to change their settings just for this situation.
Can someone please help? Isn't there SOMETHING I can do in Flash so that F10 will work without causing problems with I.E. for my users (and thus, my movie!). This is so frustrating.
Please help!
Watch Question
Unlock this solution and get a sample of our free trial.
(No credit card required)
UNLOCK SOLUTION
you can use the fscommand as hansblix suggests.. but without it being a projector file..
put it in the first frame of your movie..it will still work..sending all key events to the key up/key down onClipEvent handler in the player
Z
forgot to say..use the fscommand template when publishing..to write a javascript
function in the htnl..to action the command.
Z
Hi -
Ok... I'm very new to Flash so I want to be sure I understand the two of you.
You are saying that I don't need the Flash projector now? I can use the fscommand in the my Flash file as is? If so, can you confrim how the code should look? Where do I put in this fscommand? The following is the code I was using the movie clip that had the F10. I think you are saying that I can alter this now with this fscommand? I'm unclear. Can you clarify how I use this fscommand? Thanks
sorry so slow getting back..can only get on-line every couple of days..(remote area)
have been trying to set up a working example but can't get it to work yet..
I still contend that it is doable..will need to work on it..
what do you think of this approach hansblix..doable or not?
Z
afaik unfortunately not... The ESC key can be trapped with the trapallkeys command (in projectors)... but not the F10 key..
-h
http://www.quillem.com
UNLOCK SOLUTION
Please provide your email to receive a sample view!
OR
Please enter a first name
Please enter a last name
