daemian
simple but strange problem(plz help,a bit urgent)
I want to code a program so as to be able to read the contents(which is just numbers) of a file.This is what i have done:
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <fstream>
using namespace std;
int f,o,u1,u,w1,w2,w3,w4,w5,w6 ,w7,w8,w9, w10,w11,w1 2,count,v1 ,v2,v,l1[2 0],l2[20], l3[20],mx1 [4],my1[4] ,mz1[4],m, z,q,y,int1 ,int2,int3 ,i1,j1,q1, q2,q3,q4,u x,uy,uz,rx ,ry,rz,mx ,mz ,my ,txx, txy, txz ,tyx, tyy, tyz , tzx, tzy, tzz ,hz ,hy ,hx ,Jxx ,Jyy ,Jzz ,Jxy, Jxz ,Jyx ,Jyz ,Jzx ,Jzy;
int a[3][3];
unsigned long c[3][1];
int d1[100][100];
int d2[100][100];
int d3[100][100];
int h[3][1];
int b[3][1];
int f1,f2,i,l,j,k,t,A=2,B=2,n;
int temp1,temp2,temp3;
int main()
ifstream ifs ("inp.txt");
ifstream in_stream1;
ifstream in_stream2;
ifstream in_stream3;
ofstream out_stream1;
ofstream out_stream2;
ofstream out_stream3;
FILE *stream1,*stream4;
stream1 = fopen( "infile2.txt", "r+" );
stream4 = fopen( "outfile1.txt", "r+" );
in_stream1.open("infile2.t xt");
if (in_stream1.fail())
cout << "Input file opening failed.\n";
exit(0);
out_stream1.open("outfile1 .txt");
if (out_stream1.fail())
exit(0);
for (f = 0;f <= 11; f++)
in_stream1 >> c[f][0];
cout << c[f][0];
out_stream1 << endl;
cout << endl;
return(0);
in_stream1.close();
out_stream1.close();
and this is the file's contents:
5
8
6
7
with these specific numbers the program can only read six or seven characters!!But with other numbers e.g:
it can read all of them.What do you think the problem is?
I am using VC++ 6.0
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <fstream>
int a[3][3];
int d1[100][100];
int d2[100][100];
int d3[100][100];
int h[3][1];
int b[3][1];
int main()
exit(0);
exit(0);
cout << c[f][0];
cout << endl;
return(0);
in_stream1.close();
5
8
6
7
I am using VC++ 6.0
