ybon
Problem with Mercury (Kobian) motherboard PI845GLM-L Please help
I took a new PC of the following configuration a few days back
CPU P4 2.8GHz 533 FSB
Memory 2 Nos PC2100 DDR SDRAM 256MB each (Symmtronics make)
Motherboard Mercury (Kobian) motherboard PI845GLM-L
Other items are no of relevance to our discussion and so are not listed here
This motherboard is, as you are aware, supposed to be supporting PC2100 (DDR266) memory. However, in my case, it appears to be running at 133MHz only and not at 266MHz. Both the programs cpuZ ver 1.21 and WCPUID ver 3.3 lists the memory correctly as PC2100 (PC266) but show as working at 133MHz with FSB:DRAM ratio 1:1. I tried with another pair of Hynix DDR266 memory and still the result was same.
What I wanted to know is:
How to find out at what speed the memory is working
Is there any way to make the memory work at 266MHz speed on this motherboard
Whether the mother board is in anyway faulty in this case
Please help
Ybon
Please help
Ybon
