Printing from RichTextBox then using Printer.Print Causes Margin Problems
I am printing from a rich text box using the .selprint method. After the information from the rich text box prints, I want to print more information using the printer.print method. However, when I do this, the text I print using the printer.print method prints over the information printed from the rich text box. The information in the RTB changes, so I can't simple set a constant margin. I guess I need to know how to set the .CurrentY position based on the height of the text in the RTB. Any suggestions?
kevman123Asked:
moduloConnect With a Mentor Commented:
PAQed - no points refunded (of 500)
modulo
Community Support Moderator
Javin007Commented:
I know that there's an API to do exactly this, and I've USED it before.  But now, of course, I can't remember it for the life of me.  >:(  What you need to find out is what the api call is to get you the "height" of the lines in the RTB.  Wish I could be of more help.
-Javin
