Problems building sql statement using oledbparameter
Using sql db I get the following compile error.
BC30002: Type 'OleDbParameter' is not defined.
I am new at asp so bear with me. I got the following code off of 4guysfromrolla website.
Maybe there is a better way to build the sql statement. I am trying to get the update portion of my datagrid to update after an edit.
Sub CustomerData_Update(sender As Object, e As DataGridCommandEventArgs)
   Dim oDR as System.Data.SQLClient.SQLDataReader
   Dim oCom As System.Data.SQLClient.SqlCommand
   Dim oConn as System.Data.SQLClient.SQLConnection
   'Read in the values of the updated row
   Dim indi as String = e.Item.Cells(1).Text
   Dim lname as string = CType(e.Item.Cells(2).Controls(0), TextBox).Text
   Dim mi as string = CType(e.Item.Cells(3).Controls(0), TextBox).Text
   Dim fname as String = CType(e.Item.Cells(4).Controls(0), TextBox).Text
   Dim address1 as String = CType(e.Item.Cells(5).Controls(0), TextBox).Text
   'Construct the SQL statement using Parameters
    Dim strSQL as String = _
      "UPDATE [distributor] SET [lname] = @lname, " & _
      "[UnitPrice] = @UnitPrice, [ProductDescription] = @ProdDesc " & _
      "WHERE [ProductID] = @ProductID"
    oConn = New System.Data.SQLClient.SQLConnection ("server=mssql01.1and1.com; initial catalog=db106189075;uid=dbo106189075;pwd=aZf65Snc")
      oConn.Open()
    'Dim myCommand as OleDbCommand = new OleDbCommand(strSQL, objConn)
      oCom=new System.Data.SQLClient.SQLCommand()
    oCom.CommandType = CommandType.Text
    ' Add Parameters to the SQL query
** the error comes from the below line.
    Dim parameterProdName as OleDbParameter = new OleDbParameter("@lname", OleDbType.text, 75)
    parameterProdName.Value = strName
    oCom.Parameters.Add(parameterProdName)
    oCom.ExecuteNonQuery()   'Execute the UPDATE query
    oCom.Close()   'Close the connection
  'Finally, set the EditItemIndex to -1 and rebind the DataGrid
    oCom.EditItemIndex = -1
    Page_Data()
End Sub
Jimbo456
Jimbo456
  • 2
DotNetLover_BaanCommented:
Hi there,
you are using "System.Data.SQLClient"... and the parameter you are creating is  OleDbParameter. That's why you are having problems. It should be...
Dim parameterProdName As New SqlParameter("@lname", SqlDbType.VarChar)
Try these links:
http://www.developerfusion.com/show/4278/3/
http://msdn.microsoft.com/library/en-us/cpref/html/frlrfSystemDataSqlClientSqlParameterClassTopic.asp
-Baan
AerosSagaCommented:
tell me those aren't your actual SQL server account settings.
Join & Write a Comment
Get expert help—faster!
  • 2
