RWG
HP Pavillion XL761 power uspply replacement problems
I have a HP Pavillion Model XL761 desktop with a bad power supply. It has a Liteon model PS-6161-2H1 power supply. I replaced it with a Micro ATX V200HP power supply. Now I have no video, or I should say, I get a message saying my video adapter is installed and to go to the comtrol panel to configure it. Can't get there. My question, Is the Micro ATX power supply a correct replacement? The HP XL761 has onboard video so the video connector on the PS is not used.
Notice the 13a on the 12v line. Post what the ratings were on the original power supply and the one you replaced it with - there may be a clue there.
