Solved
ActiveX ODBC Connection Control Works in VB (and IE) but not in FOXPRO! The same control works in one but not in other! (gah)
Posted on 2004-08-13
6
Last Modified: 2013-12-25
My ActiveX Control connects to an ODBC connection (made through the control panel)
It works in VB and works in IE, (and any other activex container..)
But when i put it into VisualFoxPro6 (where it was intended to be put), it says it can't create connection or some weird error. I'll post the exact error message soon.
Thoughts?
mycode is:
rsConn.Open "termsconn" <-- that's the name of the connection. That's where its having the error.
-Michael
Question by:Anderson_Enterprises
  • 3
  • 2
6 Comments
LVL 29
Expert Comment
by:leonstryker
Please post more of your code.  It seems you are trying to open a recordset with a connection string.  Is rsConn a recordset or connection object?
Leon
Author Comment
Because you are the only guy that answered, i'm going to award you the points...
i've found the answer.
Apparently when (in foxpro) you type:
 USE Calendar
It opens a connection to the Calendar Database. (That's what I want!)
BUT..
The ODBC driver CANNOT access Calendar when its 'in use' even when you don't use it exclusive.
The solution was to Close all instances of the calendar database. Apparently ActiveX/FoxPro/VisualBasic don't like to share connections to databases. EVEN WHEN they advertise that ability.
-Michael Smyers
LVL 29
Expert Comment
by:leonstryker
Michael,
Thanks, but no thanks.  If you answered your own question, you should post to the Community Support area and ask for the question to be closed and the points refunded.  I would much rather have that happen then get a C grade.
Leon
Free Tool: Path Explorer
Author Comment
Hm, How do I go about fixing this for you? I hadn't thought about the negative connotations associated with a C..
I'll see what I can do!
-Michael Smyers
LVL 29
Expert Comment
by:leonstryker
I already made the posts.  A mod should be coming along any time now.
Leon
Accepted Solution
by:
CetusMOD earned 0 total points
Unaccepted per request http:Q_21093220.html
Closed, 500 points refunded.
CetusMOD
Community Support Moderator
Get expert help—faster!
Join & Write a Comment
Since upgrading to Office 2013 or higher installing the Smart Indenter addin will fail. This article will explain how to install it so it will work regardless of the Office version installed.
This article describes how to use a set of graphical playing cards to create a Draw Poker game in Excel or VB6.
Get people started with the process of using Access VBA to control Excel using automation, Microsoft Access can control other applications. An example is the ability to programmatically talk to Excel. Using automation, an Access application can laun…
This lesson covers basic error handling code in Microsoft Excel using VBA. This is the first lesson in a 3-part series that uses code to loop through an Excel spreadsheet in VBA and then fix errors, taking advantage of error handling code. This l…
585 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
