Solved
How Do I disconnect my wireless connection using the Linksys Wireless Network Monitor WPC54GS?
Posted on 2004-08-19
Last Modified: 2013-12-14
Hello all - I recently installed a Linksys wireless network in my home and disabled my Windows XP Wireless Zero Configuration tool as part of the installation (and per the recommendation of Linksys).  In it's place, I am using the Linksys Wireless Network Monitor v1.0.
My question is, how do I disable/drop my wireless connection when I want to continue working offline?  I would think there would be a disconnection option in the Wireless Network Monitor, but this does not appear to be the case.  Please advise how I can easily disconnect from the wireless network, short of pulling my card out. :)
Thanks!
Brian
Question by:yoda5
2 Comments
LVL 12
Accepted Solution
by:
Gary Dewrell earned 1000 total points
Hi yoda5,
Right click My Network Places, Select properties, right click on your wirless card, select disable.
God Bless
Author Comment
by:yoda5
yeah... is there any other way to do that?  once i disable from my system tray the icon drops off.  i was thinking that somewhere there was a way to disconnect/reconnect from the same spot.
Get your problem seen by more experts
Be seen. Boost your question’s priority for more expert views and faster solutions
Join & Write a Comment
This solves the problem of diagnosing why an internet connection is no longer working. It also helps identify the likely cause of the lost connection if the procedure fails to re-establish your internet connection. It helps to pinpoint the likely co…
Last month, the FCC voted to repeal Title II, the framework supporting net neutrality across all broadband ISPs. We sat down with Doug Walton, database administrator at Experts Exchange to gauge his opinion of what will happen next.
Watch the video of Kernel Migrator for SharePoint, which demonstrate the process easily of migration from SharePoint to SharePoint, OneDrive for Business & Google Drive servers, Public Folder to SharePoint, File Server to SharePoint. The tool has va…
From store locators to asset tracking and route optimization, learn how leading companies are using Google Maps APIs throughout the customer journey to increase checkout conversions, boost user engagement, and optimize order fulfillment. Powered …
584 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
