ncw
Wireless network connection causes interference with audio system
Just installed a wireless network connection and it is causing interference on the audio speaker system each time a page request to the internet is made. Any solutions?
most consumer electronics use the lower chanels, try using the higher chanels for your wireless network I use channel 11 never get much interference up there. I have done installations where I have had to start at channel 1 and work my way up for the best performance. try the upper channels first .
Good Luck
Surly
Good Luck
Surly
Surly ,
You got a good point. I kind of assumed that "ncw" would be using higher channels. my router , i think was set to work at channel 6 which is no problem.
Lets see if that can solve the issue
802.11b in the 2.4GHz spectrum. 802.11a enjoys the luxury of 12 independent, non-overlapping channels. 802.11b has 11 channels in the U.S., but only three don't overlap (channels 1, 6, and 11). Thats the channels to use if you have a wireless cam, phone, or video sender.
Surly
Surly
grblades: yes it is an internal PCI wireless card which is near to the speaker leads.
sunray_2003: the setup is a Speedtouch 510 adsl router connecting to a Dlink AP sited two floors up. The interference is crackling when there is traffic.
It's using channel 6.
The speaker is sited at high level above the PC and monitor, so the wires to the speaker trail vertically up behind the PC, so probably resiting the speakers and hence the cables may resolve the issue.
ncw,
As anyone would say , getting the AP closer to the wireless card or viceversa could solve the issue but that may not be what you can actually do depending on the situation.
Turning off audio system (power off) and other devices might also provide an answer of what might be causing them
Like Surly said , try channel 11 to see if that might help eventhough 6 should be fine i guess.
Are the sound and wireless cards in slots next to each other? If so try moving then as far apart as possible internally or placing another pci card between, maybe the interference is inside the computer, not outside!
You might also try a noise filter on the speaker wire, or replace the wire with sheilded cord.
If that doesnt work and you have the option, use an external, remote antenna on your computer. This will let you place the antenna as away from the wires.
Surly
Surly
Just curious to me what setup you have ?
Do you have a router and if yes which router ?
What type of interference do you have ? I mean in other words , what happens if you can tell in brief
Well as grblades says it would be better to move the router or access point and check if that helps.
I would be very surprised to know that should be done as I have got the following setup in my home
a) Dlink Wireless router
b) XM Satellite Radio connected to my Audio system
c) Ofcourse the Antenna for FM and AM for the Audio system
All these are in the same room and the room is not a big one. I have not faced any interference issues with my wireless card , whatsoever. My wireless card is by Lucent
I have heard issues here where wireless and Cordless phone have issues. DO you have your phone aswell ?
SR..
