Using a variable from pl/sql block into shell script
  I have a shell script like this.
awk -F"," 'BEGIN{cnt = 0; OFS=","}
IF FILENAME == "fin.csv"{
test_field[cnt] = $1
field[cnt] = $1","$2","$3","
for (a=1;a<=cnt;++a){
if ( test_field[a] == "LOCATION" )    ####   DROP HEADERS IF ANY
 print field[a] > "financials.csv"
'}} fin.csv
lc_dump_count = wc -l financials.csv
1>>$LOGFILE sqlplus -s crebatch/crebatch@credvl <<SQLRUN
       lc_data_count number;
       select count(1) into lc_data_count from XYZ;
if (lc_data_count = lc_dump_count)
mailx -s "Counts are good `date`" < $LOGFILE
mailx -s "Counts are not good `date`" < $LOGFILE
1)  I want to send the count of table XYZ into a variable called 'lc_data_count' and compare it with the variable called 'lc_dump_count'. Of course this code isn't working because lc_data_count is a variable with the pl/sql block. What will work then?
2)    Will this code work?
3)    Any suggestions on how to get the whole line into a variable instead of doing
    I have like atleast 25 values.
tfewsterConnect With a Mentor Commented:
2)  wc will return the filename as well as the line count; To get around that:
lc_dump_count=`wc -l financials.csv |awk '{print $1}'
lc_dump_count=`cat financials.csv | wc-l`
awk syntax to build up a string:
field[cnt] = $1
for (x=2; x<=NF; x++) {print x; print $x; field[cnt]=field[cnt]","$x}
print field[cnt]
Thank you, but you could have left the question open until your main point about capturing output from SQL was answered and then split the points...I've not touched SQL for years, but is it possible to send the output of the "select count(1)"  to a flat file, which you could then read with e.g.:
lc_dump_count=`cat mycountfile`
Or grep the results of the count out of the LOGFILE?
I just noticed a couple of minor things:
LOGFILE=logfile.log   (Not "$LOGFILE")
I think this should be:
if [ lc_data_count -eq lc_dump_count ]
'}} fin.csv
should be
}}' fin.csv                    (position of " ' " )
Duh - (*slaps tfewster*)
if [ $lc_data_count -eq $lc_dump_count ]
I guess you can delete the other question ;-)
Free Tool: Path Explorer
sumanth_oraAuthor Commented:
    I got my answer for that first question before you answered for it. This is how I did it.
lc_data_count=`sqlplus -s crebatch/crebatch@credvl <<SQLRUN
                 set head off
                 select count(1) from fin_data;
   This worked perfectly fine.
As for the variable equality check, I used:
if (($lc_data_count==$lc_dump_count))
    This worked fine too.
     And I don't know why, but
'}} fin.csv
  worked.   But I will try with
}}' fin.csv
  and see.....
And this works fine too:
mailx -s "Hi" < $LOGFILE
    this gives me a valid email.
And one more thing....
   This 'awk' script you gave is taking longer to parse when compared to what I had. I am guessing this is because of the extra FOR loop in the script.
   Just to let you know....
