Phil500
Dual Monitor works when first set up, but when system restarted reverts to single laptop monitor
Hi, I have been running a laptop with a monitor also attached, so using dual monitor/ display. The external monitor is the identified as 1 with the laptop LCD 2 when I restarted it would restart in the dual mode, no problems. Everything has been fine for over 1 year then about a week ago, on restart it starts in single monitor (LCD only) once logged in goes to dual monitor, but keeps making the laptop the primary monitor. So I change it via Display, all ok then restart and back to starting in LCD screen only.
I'm running XP pro, I then a system restore, loaded new drivers, load new software from ATI for RAdeon, still not fixed. Does anyone have any ideas ?
Cool! It's good that you got it working.
