Paul197466
FTP connection problems using TIdFTP
OK, I have a Delphi 7 application that is using the Indy TIdFTP component for connecting to an FTP site.
The application works fine on my PC but fails to connect (with timeout message) on client's PC, when using same login credentials to same FTP site.
Thinking that it might be a firewall/ proxy problem, I had them use WS_FTP Pro (an FTP client) to connect to the FTP site with same login credentials - worked fine
Any thoughts on what else might be causing this problem, gratefully received!
Did it work fine on the client machine or was it only from your machine? One think you might check is the firewall setting on the server. It might be set to letting only IP from your PC and not your clients'.
Another way of testing this is by telneting to your server from your client's end. Just telent to the FTP port and see if it connects from the client's machine.
-Ram
-Ram
The FTP server is not on my network.
They could connet to this server using FTP client
Ahh, what are the units for timeout parameter in TIdFTP.Connect? Seconds or milliseconds? I couldn'g find this documented anywhere!
I was assuming seconds
I noticed someone else had problems with this componen on XP?
