Power supply will not come on with HD pluged into power.
I have a pc that just up and stoped working so to TS it I changed the powersupply and that didn't solve the problem so I started by unpluging one thing at a time and it will start with the hd unpluged.  Can a hd cause a powersupply to stop working?  Maybe a short.
m_rawson
m_rawson
buckeyes33Commented:
I would assume so.  Although I have never seen a hard drive do it.  I have seen a floppy drive do it, which I figured was shorting out.  So I would assume that your board on the hard drive is bad.
if there is important data on the hard drive you can swap out the board.  The process is not to difficult, but does take some machanical ablity and the correct bit.  You would have to get a board for the exact same model number as the current drive.
_Commented:
Yes. I have run into this a couple of times when stripping systems and testing parts.
Buckeye gave you the way to fix this if you have data you have to get the drive.
WakeupSpecialist 1Commented:
I too, have come accross this problem several times.  Also realize that the info buckeyes33 gave for retrieving data off a dead drive is basically correct, however the HDD Board has to be the same revision, not just the same model drive.  Sometimes there are different revisions, which may change the way the drive is accessed and the like.  So if you had the wrong revision board, it still may not work.  Or you wont be able to get the data off the drive.
Free Tool: Site Down Detector
good point wake.
do you want some more information on changing the board?
m_rawsonAuthor Commented:
Sure do I have to get it from the manufacture and is this something that they usually do?
if the hard drive is still under warrenty then you can probably do one of two things.  Send the drive to them to have them do it.  Or they will send you another hard drive or a board of which you would have to put on.  Most of the hard drive companies will do whatever you want to do and feel you can do.  They want to make you happy as there is a lot of competion in that industry right know.  You should probably call the manufacturer and see and decide on which you want to do.
If the hard drive is not under warrenty, then you will just need to search for a hard drive that is exactly like yours.  Then change it out yourself.
Join & Write a Comment
The 14th Annual Expert Award Winners
The results are in! Meet the top members of our 2017 Expert Awards. Congratulations to all who qualified!
