Solved
XP Home/Pro access problems with small networking solution via wirless network
Posted on 2004-09-01
Last Modified: 2010-03-18
I have two desktop computers, one running Windows XP Home connected to the internet via a wire to a wireless router and another running Windows XP Pro connected to the internet via a wireless connection (PCI Card). They are called Jenniespc and Richardspc respectively.
Now the Jenniespc (Home Ed) can access all the computers on the network just fine, but Richardspc (Pro Ed) can only access the internet and its own shared files.
Also when I click on "view workgroup computers" in "My network places" and try to access Jenniespc from Richardspc I get the error message "\\Jenniespc is not accessible. You might not have permission to use this network resource. Contact the administrator to find out if you have access permissions. Access is denied."
Both PCs belong to the same workgroup (lewis-net).
Both PCs can ping each other via IP and "PC Name".
Both PCs windows firewall is turned off.
Richards PC has disabled simple file sharing.
To me it seems like the Home Edition of XP is not granting access properly, can anybody help me please?
~ Craig
Question by:Sk8rRIMuk
[X]
Welcome to Experts Exchange
Add your voice to the tech community where 5M+ people just like you are talking about what matters.
  • Help others & share knowledge
  • Earn cash & points
  • Learn & ask questions
3 Comments
LVL 57
Accepted Solution
by:
Pete Long earned 1500 total points
Networking XP
*****Most Networking Problems with XP*****
Are caused by Firewalls (either hardware or software)
If you have Zone Alarm, Black ICE Defender etc turn them off! If the problem goes away, you need to reconfigure the firewall. Also Windows XP by default has a built in firewall (ICF) to disable
1.  Open Network Connections (Click Start, click Control Panel, and then double click Network Connections.)
2.  Click the Dial up, LAN or High–Speed Internet connection that you want to protect, and then, under Network Tasks, click Change settings of this connection.
3.  On the Advanced tab, under Internet Connection Firewall, select the following:  Clear the Protect my computer and network by limiting or preventing access to this computer from the Internet check box. This disables the firewall; your computer and network are then vulnerable to intrusions.
*****Full Walkthrough of networking XP Home*****
How to Set Up a Small Network with Windows XP Home Edition (PART 1)
http://support.microsoft.com/default.aspx?kbid=813936
How to Set Up a Small Network with Windows XP Home Edition (PART 2)
http://support.microsoft.com/default.aspx?kbid=813937
How to Set Up a Small Network with Windows XP Home Edition (PART 3)
http://support.microsoft.com/default.aspx?kbid=813938
How to Set Up a Small Network with Windows XP Home Edition (PART 4)
http://support.microsoft.com/default.aspx?kbid=813939
How to Set Up a Small Network with Windows XP Home Edition (PART 5)
http://support.microsoft.com/default.aspx?kbid=813940
How to Set Up a Small Network with Windows XP Home Edition (PART 6)
http://support.microsoft.com/default.aspx?kbid=814003
How to Set Up a Small Network with Windows XP Home Edition (PART 7)
http://support.microsoft.com/default.aspx?kbid=814004
How to Set Up a Small Network with Windows XP Home Edition (PART 8)
http://support.microsoft.com/default.aspx?kbid=814005
Networking XP and 2000
http://www.homenethelp.com/web/howto/HomeNet-Win2kXP.asp
Adding XP to a network
http://www.practicallynetworked.com/sharing/xp/addxp.htm
Windows XP Network troubleshooting
http://www.practicallynetworked.com/sharing/troubleshoot/
Author Comment
by:Sk8rRIMuk
I have just been through all of that stuff after you posted it and it's still not working, thanks for the ideas to try though.
LVL 2
Expert Comment
by:bigmanjer
You probably have to set up a user account on Jenniespc to match your account on Richardspc.  Make sure it has the same name and password as your login to Richardspc.  Also double check your Network Connection (on both machines) to make sure Firewall is turned off.
- Jer
FIPS stands for the Federal Information Processing Standardisation and FIPS 140-2 is a collection of standards that are generically associated with hardware and software cryptography. In most cases, people can refer to this as the method of encrypti…
Enterprise networks where VoIP phones have been deployed frequently use port configurations that allow both a computer and an IP phone to be plugged into the same switch port but use different VLANs. On Cisco equipment I'm referring to the "native V…
Michael from AdRem Software explains how to view the most utilized and worst performing nodes in your network, by accessing the Top Charts view in NetCrunch network monitor (https://www.adremsoft.com/). Top Charts is a view in which you can set seve…
In this video you will find out how to export Office 365 mailboxes using the built in eDiscovery tool. Bear in mind that although this method might be useful in some cases, using PST files as Office 365 backup is troublesome in a long run (more on t…
771 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
