Solved
Process problem : Permission problem (eTrust Audit)
Posted on 2004-09-04
Last Modified: 2013-12-27
I have received the following messages when I try to start up process, I have 'su' as a privilged user already:
#./acrecorderd -start
ld.so.1: ./acrecorderd: fatal: librpcsoc.so.1: open failed: No such file or directory
Killed
I tried to restart eTrust Audit Recorder as per the manual describe, but I get the same error as with other process.
 I believe it is a permission problem.....
Any help is appreicated.
Question by:nicotine1
1 Comment
LVL 19
Accepted Solution
by:
ramazanyich earned 2000 total points
It is a problem with loading of librpcsos.so library. Possibly it is not placed into standard lib directory (/usr/lib). You have to add path to library into LD_LIBRARY_PATH environment variable.
So first you have to find where your library is situated:
find / -name librpcsoc.so.1 -print
Let say that it will find it in /usr/some/lib directory.
Then before calling your acrecorder programm execute follwoing command:
>LD_LIBRARY_PATH=/usr/some/lib:$LD_LIBRARY_PATH; export LD_LIBRARY_PATH;
Free Tool: Path Explorer
My previous tech tip, Installing the Solaris OS From the Flash Archive On a Tape (http://www.experts-exchange.com/articles/OS/Unix/Solaris/Installing-the-Solaris-OS-From-the-Flash-Archive-on-a-Tape.html), discussed installing the Solaris Operating S…
Every server (virtual or physical) needs a console: and the console can be provided through hardware directly connected, software for remote connections, local connections, through a KVM, etc. This document explains the different types of consol…
Learn several ways to interact with files and get file information from the bash shell. ls lists the contents of a directory: Using the -a flag displays hidden files: Using the -l flag formats the output in a long list: The file command gives us mor…
In a previous video, we went over how to export a DynamoDB table into Amazon S3.  In this video, we show how to load the export from S3 into a DynamoDB table.
Suggested Courses
Course of the Month4 days, 5 hours left to enroll
599 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
